4.040 bores inside please?
Old Nov 13, 2006 | 10:38 AM
Vicious95Z28's Avatar
Just wondering how many of you are 40 over , do you have any problems?
Old Nov 13, 2006 | 03:08 PM
blackztpi's Avatar
.045 over here. you will hardly ever have a problem with 40 over
Old Nov 13, 2006 | 03:16 PM
good to hear
Old Nov 13, 2006 | 04:28 PM
On the other hand, starting with less overbore will leave you with stronger cylinder walls and room for a future freshening. I started with 4.020"
Old Nov 13, 2006 | 04:47 PM
lethal93ta's Avatar
I went 4.030 just due to being able to get a standard piston off the shelf for in mine, I would have only went .010 over if I wouldnt have had to order a custom set of pistons.
Old Nov 13, 2006 | 06:02 PM
engineermike's Avatar
I'm at .060" over and 20+ psi boost with no problems (with the block, at least). That said, Injuneer is right, less is better because it leaves you more strength and cylinder wall for later rebuilds. Knowing what I know now, I would have just honed it to 4.002 and put some standard pistons back in it the first go-round.
Mike
Old Nov 13, 2006 | 09:41 PM
BadBowLT1's Avatar
TPIS has went as far as 4.100 but they said only certain blocks are capable of it
greg
Old Nov 14, 2006 | 08:35 AM
NJLT1SS's Avatar
I spent a little extra money on my pistons, and custom ordered a set at 4.010. I just didnt see why I should go 4.030 for the first build on a virgin block, when it cleaned up fine at 4.010. I was thinking ahead for future rebuilds.
Nick
Old Nov 14, 2006 | 09:58 AM
Z-RATED94's Avatar
Nick
Smart move in my book.
Old Nov 14, 2006 | 10:35 AM
I'm not really concerned about redoing the engine. The next time it come out it'll prolly be for a crate motor. I foud the Mahle powerpac for about $490 shipped, is that a pretty good price? It seems to be. Where do you guys get your Powerpac from?
IndyZman
Oct 22, 2015 02:17 PM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
heus
Sep 8, 2015 12:01 PM
