3rd set of O2's?!
Old Sep 13, 2007 | 02:45 PM
thecamarokidz28's Avatar
3rd set of O2's?!
I have a 93' Camaro with longtubes and true duals. I installed a set of heated O2 sensors (93s did not come with them) about 8-9 months ago. The first set lasted until this past Spring of 07. I replaced them with brand new Delcos and both of those crapped out on me and I just put a new set in today. Everytime they go out the car starts missing real bad at part throttle because it jumps in and out of closed and open loop. The new O2 sensors always fix it though. Any ideas on why the new sensors dont last very long?
Old Sep 13, 2007 | 04:54 PM
mrmint69's Avatar
I have no idea if it mattered but why did you use heated O2's if your car came with non? I know running real rich can foul them as well as the ceramic coating as it burns off. It could be a number of things but strange they go out as a pair. Did you confirm this with a scanner?
Old Sep 13, 2007 | 05:19 PM
People with 93's convert to heated sensors, because the long tubes move the sensors too far from the engine, and they don't stay hot enough to operate.
I would check the wiring harnesses to insure there is not some way that the +12V used for the heater circuits is not bleeding through to the 1V sensor element circuit.
Old Sep 13, 2007 | 07:41 PM
dangalla's Avatar
just an idea, they dont apear to be coated with anything like oil do they
Old Sep 14, 2007 | 01:49 AM
Ok4thGen's Avatar
Did you make the extension yourself? could very well be a poor connection problem.
Truthfully me personally i havent made the change to a heated O2 sensor on my maro it plain and simply does not go in open loop other then extended time on the highway.
Old Sep 14, 2007 | 05:21 AM
Originally Posted by Ok4thGen
....i havent made the change to a heated O2 sensor on my maro it plain and simply does not go in open loop other then extended time on the highway.
Seems odd that it only drops out of closed loop under extended cruise conditions. May be the cooler exhaust temps due to EGR use.... if you still have EGR. Why allow it to do that?
Old Sep 14, 2007 | 08:49 AM
Ok4thGen's Avatar
I dont have egr on my car, nor do i leave town much at all it never goes into open loop in town.
Old Sep 14, 2007 | 11:02 AM
no oil, but I think this set may have been takin out because the wires on my car were shot pretty much all summer. The car was running rich and when I pulled the O2s yesterday they were pretty black. Hopefully that was the problem and I now have OTVC wires.
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
FredM
Mar 6, 2015 03:04 PM
Jan 23, 2015 01:13 PM
snksknr94
Aug 2, 2002 07:31 PM
Trevor98ramair
Jul 31, 2002 02:43 PM
