396 + stock cam = ??? bs?
I was just told that this 396 build has stock cam and pulled 8 cars from a 20mph roll on a car that ran 11.7 in the quarter. I dont find this possible on a stock cam? He didnt even say heads are ported just a valve job
this is all i can give you. i should be getting more info on everything tomorrow.
Engine:
-Eagle Forged Crank
-Eagle Forged Rods
-SRP Forged Pistons
-PRW Aluminum Blue Roller Rockers
-Heavy duty Valve Springs
-Heads are aluminum and have been ported and polished, and portmatched to the headers
-New heavy duty valves
-Hooker Super Comp Ceramic coated long tube headers.(3" Collectors)
-K&N Cold air intake
-MSD Blaster Coil/8.5 mm Super conducter wires/Distributor Cap&Rotor
-LT4 Timing set
-All Seels & Gaskets new
-All ARP Bolts and Studs
-Waterpump new, with new thermostat
Transmission:
-6 Speed
-Fidanza 6 Pucked ceramic Stage 4 Clucth
-Lighthed Flywheel(Balanced)
-Fidanza Pressure plate(Balanced)
Engine:
-Eagle Forged Crank
-Eagle Forged Rods
-SRP Forged Pistons
-LT4 Timing set
Transmission:
-6 Speed
hmm
id say it could run decent on a stock cam. but it would DEFINATLEY never ever reach any where near what it can do on a stock cam. it would be like putting an l98 cam in an lt1. i dont see why the would leave the stock cam in. hell they built everything else. i doubt it is a stock cam, i bet its on a stock lsa to be more like a sleeper.
Crank: Eagle 4340 Forged steel crank with 3.875 stroke
Rods: Eagle forged H Beam Rods 6"
Pistons: SRP Forged 4.030 pistons(.30 Over)
Rings: Perfect circle Rings (Gapped for nitrious or boost)
Bearings: Clevite bearings
thats what he just sent me. any help?
heres what i got in another email
"Yes its the stock LT1 cam with the 1.6 roller Rockers which changed the overall lift which makes it perform like a higher lift cam like I said before, and my dad undercut the valves for extra flow."
Not a chance in hell, he's full of **** in either it being a 396, or the 11.7 car with 8 car lengths...
Not to mention if you're doing a 396, why would you just do a basic head job and not even P&P the heads... something's afoul...
i have a feeling its actually a 396 with no money into heads and a stock cam. i think it was a dumb thing to do. he says hes got the receipts for all the motor work so we will see. i am going to see it wednesday. ill probably drive it and be able to tell how well it runs
BLUETOPTA
30
Sep 18, 2002 12:22 AM
