396 running, coolint coming from two head studs
Old Feb 28, 2004 | 06:54 PM
  #16
Botch's Avatar
Originally posted by dreamer1q
Chances are that the oil leak is due to the JUNK STATUS OF CANTONS OIL PANS. They are total junk and I suggest you sell it and buy a Miledon. But hey, thats just me and I personally have one and know how bad the SUCK!!!!!!!!!!!!
Ditto!
I put my (1st one) on and it leaked like a siv. Faulty welds were to blame. I recieved my 2nd one and the oil level sensor wouldn't go in it because they screwd up the baffling and I sent it back again. They took 3 freaking weeks to do a 1/2 a$$ed hack job rework on my pan and sent it back. Now my pan is POS and I waited 2 months, get a different pan. I cleaned at least two teaspoonfulls of welding slag and wire out of it before I installed it, and I would have never freaking known if I hadn't just "made sure" prior to putting it on. CANTON SUCKS
Old Feb 28, 2004 | 07:34 PM
  #17
iniviate's Avatar
my canton pan was a *little* warped when set on the motor... but that's with no bolts in it.
i used a GM pan gasket, with a little ultra black on both sides. no leaks. infact, the last time i took my motor apart, i actually bent a corner of the pan slightly trying to get it to break the seal loose.
it's currently sealed up, not leaking any oil, even with the bent lip.....
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Catmaigne
Dec 25, 2014 12:16 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
bman555
Aug 11, 2002 10:56 PM
