396 Dynoed @ 467RWHP need Z06 MAF???
Old Oct 23, 2004 | 09:05 PM
  #16
96capricemgr's Avatar
Re: 396 Dynoed @ 467RWHP need Z06 MAF???
Yes it is 5 wire with an IAT(we can't use the IAT though).
Old Oct 23, 2004 | 10:27 PM
  #17
fmsracing's Avatar
Ttt
Old Nov 8, 2004 | 03:53 PM
  #18
snorkelface's Avatar
Question Re: 396 Dynoed @ 467RWHP need Z06 MAF???
Did you ever come to a conclusion regarding the ZO6 MAF?
I called SLP, and they say that they don't offer an LT1-calibrated ZO6 MAF. So, that would mean that we would need to have a custom tune, along with the Ramcharger's adapter (only $18) just to make it work?
Old Nov 8, 2004 | 04:59 PM
  #19
TQdrivenws6's Avatar
Speed Inc sells one. I believe its $150 including the maf and the convertor/translator.
Old Nov 8, 2004 | 05:02 PM
  #20
amean94ta's Avatar
i would like to know your combo. 467 sounds low. small cam? low compression? stock heads? whats the deal
Old Nov 8, 2004 | 05:15 PM
  #21
Speed Inc does have it. That's perfect!
Thanks.
Old Nov 8, 2004 | 08:02 PM
  #22
med_reject's Avatar
granatelli makes a maf for the lt1 that is 85mm, and its plug and play. Why not just use that?
Old Nov 8, 2004 | 08:09 PM
  #23
A Granatelli MAF is hit or miss. Many times, a person could experience a power loss. I tried one on my car, and it caused a miss under load. Also, it's twice as expensive.
Old Nov 8, 2004 | 08:26 PM
  #24
I tried the ZO6 MAF along with a better intake on my car and lowend responce was better but BLMs are bad and things are falling off topend. This was with tables on got on this forum. I agree with BH and Ion this thing is more trouble than it is worth and was a total waste of my money.
The Granatelli is not a good thing would call it worse than the ZO6 even.
If someone wants to try it I will sell the ZO6 sensor with a plugin extension/adapter(make an offer), and am looking for a stock with screen LT1 f-body sensor.
Old Nov 8, 2004 | 08:28 PM
  #25
fmsracing's Avatar
I just got the Z06 MAF on and to the dyno last weekend. I guess there was a need for more air, because I made 28 rwhp and 33 rwtq more with this setup and a my PCM reprogramed. Thanks for all the input.
Old Nov 9, 2004 | 12:25 AM
  #26
I wasn't getting a strong MAF signal, so my car was running off of the preprogrammed tables. I cleaned the MAF, and it is working correctly, but the car feels slower now.
Any thoughts???
Old Nov 9, 2004 | 06:31 AM
  #27
97FormulaWS-6's Avatar
I've been running the Z06 MAF with the programmed PCM for almost 3 years now with zero issues. BLMs are flat and steady, everything else works mint.
Infact, I can imagine how many people downloaded the tables that I'm running with on my car.
**Side note/thought** I'm wondering if the intake track design is effecting things again on some people's cars. The Z06 W/O the screen was tested for use on the Z06's straight-shot intake; I would bet to say that most people who have issues with this are running a conventional style setup; unlike my WS6 straight-shot intake. Otherwise I'm not quite sure what could be causing things.
I do know the range of the Z06 MAF is actually less when used on a LT1 PCM, but it's resolution is quite a bit better than the LT1 Stocker. I'm also wondering if some of the people who are having issues with this MAF are running higher HP/airflow motors are are maxing out the inputs to their PCM.
Old Nov 9, 2004 | 08:28 AM
  #28
FASTFATBOY's Avatar
Where did you get the MAF and what did it entail to make it work?
David
Old Nov 9, 2004 | 10:10 AM
  #29
1racerdude's Avatar
And some people on this board say the 227's are to big or to much trouble to make HP with a 383 or larger.
I will repeat "you can't put to much head on it"(give the available castings) as long as you have an intake tract to match.
Old Nov 9, 2004 | 11:37 AM
  #30
amean94ta's Avatar
also dont forget that the 227's shine from 6k up and the stock computer dont. so if you have a fast or similer its best
