383 Woes continue, what do you think?!
Old Nov 11, 2005 | 08:31 AM
  #16
97WS6SCharged's Avatar
Re: 383 Woes continue, what do you think?!
The map sensor should be fine. He's running a set of heads that flow 28x/21x and a cam with a 24x/24x duration, that's why the sensor is reading funny.
Out of curiosity, is the whole exhaust system hooked up yet or are you running it with open headers?
Old Nov 11, 2005 | 09:19 AM
  #17
TQdrivenws6's Avatar
Get the idle in check first. Your IAC is way high, and TPS is higher than ideal. Open the throttle blades until you see the IAC drop to 40 and then slot the TPS and get it to be around .5v at idle. What O2 sensors are in the car?
Old Nov 11, 2005 | 01:13 PM
  #18
NVetro's Avatar
97WS6SCharged: Yes his whole exhaust system is connected.
TQdrivenws6: When we got his TPS voltage down to the 50's the alignment of the holes was impossible to correct....meaning, half the bolt hole from the tb was still showing through the bolt hole of the sensor....we would have to enlarge the bolt hole on the sensor and then it wont stay in place at all im sure...any ideas?
Old Nov 11, 2005 | 01:59 PM
  #19
You will probably need to slot the TPS holes, dont just drill them oversize. You need to get both the IAC & TPS into spec before trying to diagnose what else is being a problem.
Old Nov 11, 2005 | 07:08 PM
  #20
ChrisUlrich's Avatar
27 - EGR Electrical Fault (QDM)
26 - Quad Driver Module (1 Fault)
Then we scanned it again (After installing NEW map sensor)
Map Sensor was being read on the scanner.
Do any of those have to do with the tuning? I have no EGR, AIR, or EVAP... but they aren't tuned out of the PCM, could this be a factor?
Old Nov 12, 2005 | 08:17 AM
  #21
The code 26 is for the charcoal canister purge relay. 27 is the EGR activation relay. Neither should affect the car beyond triggering a SES light.
Do you still have a copy of that tune on a disk or something?
Old Nov 13, 2005 | 03:27 PM
  #22
Tune is good, I called Ion to verify.
Although EGR/AIR/CCP were not deleted, i'm going to upload a new tune for those, but I was told they have nothing to do with the cars behavior.
I'm at a loss... please give me some ideas.
Formula Steve
Sep 19, 2023 08:31 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
Z Power
Sep 19, 2015 11:19 PM
NewsBot
Sep 15, 2015 11:53 AM
