383 Woes continue, what do you think?!
Old Nov 10, 2005 | 04:10 PM
ChrisUlrich's Avatar
O2 are going from 400's to 800's at idle
tps voltage seems high at .086 volts
IAC Count seems high at 144
Knock Retard is 0.0 deg
Note: Car idles great... flawless until closed loop occurs
Old Nov 10, 2005 | 04:14 PM
blkchevyz's Avatar
Re: 383 Woes continue, what do you think?!
sounds like you need to open the throttle blades up a little. your iac count is maxed out.
strange thing is your tps is high... that should read like 60 or so. did you just put an aftermarket throttle body on also?
what are you o2 sensors doing once it gets to close loop?
Old Nov 10, 2005 | 04:22 PM
NVetro's Avatar
he has a bbk 58mm tb....the o2's are fluctuating from 400's to 800's when in closed loop and the blms i think were either pined at 108 or 128.
Old Nov 10, 2005 | 04:26 PM
blkchevyz's Avatar
oh damn i didnt read, i thought his idle was fluctuating from 400-800
what cam are you running? any exhaust leaks
NVetro's Avatar
Here are some screen shots from the scans we ran, both open and closed loop. If the image comes up blurry then save it to ur hard drive and open it, mite be a browser thing. Check it out, what do you all think....
Open Loop
http://www.angelfire.com/nj4/96blackws6/openloop.JPG
Closed Loop
http://www.angelfire.com/nj4/96blackws6/closedloop.JPG
EDIT: Cant direct link the images, just copy the image address and past it in a new window.
Thanks.
Old Nov 10, 2005 | 04:41 PM
blkchevyz's Avatar
from what your blm are saying its way lean to were it cant even adjust for it.
since it runs great till it goes to im thinking the reading is false. i would really look for exhaust leaks.
or bad o2 sensors.
Old Nov 10, 2005 | 04:59 PM
97WS6SCharged's Avatar
It ain't lean. 108 means it can't pull out anymore fuel, anything over 128 is lean.
Hard to figure out anything with just snapshots, do you have a way to log it for a few minutes? Is it still shutting off when it hits closed loop?
Old Nov 10, 2005 | 05:18 PM
NVetro's Avatar
It runs and idles perfect in open loop, once it hits closed loop it gets real shaky, idle is iradic, drops to 500rpms, back up, back down, half to give it throttle to keep it goin, sometimes throttle wont respond and it'll just die....If the car was always in open loop it would be fine, think o2's is the only issue?
Old Nov 10, 2005 | 05:31 PM
Like I said, it's hard to tell with just snapshots. Does the left O2 move? In those pics, it's stuck at 444 mv.
Old Nov 10, 2005 | 05:57 PM
blkchevyz's Avatar
yep im backwards today... where's the coffee at
Old Nov 10, 2005 | 06:05 PM
Nah Chris, they are going from 400-800 mv on both sides. Car runs perfect during open loop. Closed loop and it falls on it's face. Both 02 readings going from 400-800.
BLMs and DELs are also in the 108-120 ranges on both banks.
Old Nov 10, 2005 | 06:37 PM
ZZ17IROC's Avatar
Did you have your ECM re-flashed for your new set-up? If not I maybe able to help you figure it out.
Old Nov 10, 2005 | 06:40 PM
Yea, it was tuned by Ion @ MadZ28.com
Old Nov 10, 2005 | 06:47 PM
ZZ17IROC's Avatar
Is your map sensor in good working order? Because it looks like its not plug in on your data logs and also both of the logs are in closed loop.
I'm going to PM you my phone #. So call me up if you can?
Old Nov 10, 2005 | 07:21 PM
turbo_Z's Avatar
Map looks kinda high.
Id adjust the injector constant. My guess is you have larger injectors but not the programming to support them.
