383 Woes
Old Oct 26, 2005 | 03:37 PM
  #16
valter's Avatar
Re: 383 Woes
Check wiring. MAP and TPS readings looks right? What's with tune?
Old Oct 26, 2005 | 04:12 PM
  #17
BUBBA's Avatar
Re: 383 Woes
I assume that when you say you checked the gaps, that you are mean you squared the ring in the combustion (top 1") of the bore with either a square tool or the upsidedown piston itself and measured the gaps, and of course you are certain you installed the "correct" rings and that the gaps were correct.
Just checking.
Good luck.
Formula Steve
Sep 19, 2023 08:31 AM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
