383 w/ stock heads
Old Jan 31, 2006 | 01:16 PM
96LT1TX's Avatar
383 w/ stock heads
Would anyone see a problem w/ me running this? it will be a forged 383 w/ my 230/236 112 LSA cam and stock heads. I just want to drive the damn thing again! if this will cause problems I will not even try it w/ that, and wait for the heads/cam.
thanks
Old Jan 31, 2006 | 02:00 PM
ChrisUlrich's Avatar
Re: 383 w/ stock heads
The power comes from the heads/cam really. The 383 I guess will add some power but it won't be your typical power having 383.
Old Jan 31, 2006 | 02:12 PM
BlackScreaminMachine's Avatar
383 w/ stock heads = disappointing, get head work done. I know from experience. I had ported heads but a SMALL cam. Now im going for a Bret Bauer cam!
Old Jan 31, 2006 | 03:31 PM
FastZinTennessee's Avatar
It won't cause any problems, but you really do need some extra cfm over the stock heads to properly feed the extra cubic inches. If you put it together with the stock heads now, you'll just be tearing it apart later to do it right, or the alternative is to have a sub-par 383.
Old Jan 31, 2006 | 03:39 PM
Zigroid's Avatar
that wouldnt be a very high revving 383.
I bet it would make decent torque down low.
Old Jan 31, 2006 | 05:35 PM
96LT1TX's Avatar
in 2-3 months i MIGHT have enough money for a good heads/cam swap, but not yet... so that is the reasoning behind it... I bet it will run faster than it did w/ same cam on the 350 which was somewhat impressive.
Old Jan 31, 2006 | 05:40 PM
LameRandomName's Avatar
No, it won't cause "problems". It will simply choke off your 383 at a fairly low RPM.
When you get the money for a set of good heads later on, they'll have a big impact.
Old Feb 1, 2006 | 12:47 PM
96LT1TX's Avatar
ok so when this motor "chokes off" what is it going to do? Just drop power like a spike? are we talking like 5,000rpms or something that low? because the cam goes to 6100-6200rpms. I just want it to be faster than it was with the 350 and the same cam... which I am guessing would easily happen?
thanks again
Old Feb 1, 2006 | 01:50 PM
97bowtie's Avatar
thanks again
The motor will probably peak around 5600 - 5800 or so, and fall off pretty quickly.
Old Feb 1, 2006 | 03:29 PM
WS Sick's Avatar
If youve ever driven a TPI car, it would feel like that.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
