383 surges like crazy?
Re: 383 surges like crazy?
hey turbo z do you have a data logging cable? Ion thinks im going to have to datalog a run for him to help me out.
anyways with a snap on scanner heres some data
Map (HG) at 1000rpm 10-11
" " slow throttle up to 2500 7.5
" " throttle blimped to 2500 22
Map V 1.5V at 1000rpm
" " .8 @ 2500rpm
IAC values at idle 25-35
o2s at idle seem to fluctuate mainly around 400-600 but vaiying all the way from 160-900
please help me get this figured out.
" " .8 @ 2500rpm
Vacuum looks good at 1000 rpm but I was really looking for a reading at 800 rpm. O2s and IAC look ok. And yes I do have a cable and laptop.
what are your plans for this weekend? i really am out of ideas with this car, and i guess i just need to get it datalogged do you think if came down to manhattan you could help me out with that? thanks again
still looking for help with this. the best i could describe the problem while driving around is like a horrible cam surge. maybe if i was running a cam with like 240/250 durration without a tune. anymore suggestions?
Same here. I can't drive at low speeds smoothly. I must press the clutch pedal or must keep the RPM above 2500. Otherwise its like riding a horse.
Thats like your problem?
Ryan Ramsaran
Sep 19, 2015 08:43 PM
