383 or supercharger
Old Oct 16, 2010 | 09:01 PM
jdelaprida's Avatar
383 or supercharger
I have a 96 camaro z28..
I have a few bolts ons intake, exhaust, headers.
I'm trying to deside either to build a 383 or just get a supercharger.
I've been looking into vortechs, and superchargers, but really haven't found any for sale, so if you can send me a link to one, if thats the way to go superchager, not 383.
Old Oct 16, 2010 | 10:18 PM
BlackbirdWS6's Avatar
What is your budget? Desired power level? Purpose of the vehicle?
These factors play a big part on which direction is the best overall depending on your goals.
Old Oct 17, 2010 | 06:54 PM
jdelaprida's Avatar
$5000
im looking to make a street car.
Im not trying to change my gears in it.
And i want it to atleast be around 12s with the stock gears.
Old Oct 17, 2010 | 07:45 PM
If you are looking for 12s for $5k, I would just stick with your stock shortblock and get a nice heads/cam setup. Go with a LE2 or AI setup and I think you will be happy. Blower builds are $ and a budget 383 on a $5k won't be all that amazing.
Including the supporting mods for a nice heads/cam setup may come in under $5k even and if that's not fast enough, throw on some nitrous
Old Oct 17, 2010 | 08:08 PM
jdelaprida's Avatar
I'm kind of new with this whats a LE2 or AI setup?
Old Oct 17, 2010 | 08:19 PM
MikeGyver's Avatar
Also if you build a motor you'll have a brand new motor
http://elliottsportworks.com/
http://www.advancedinduction.com/
Old Oct 17, 2010 | 10:02 PM
jdelaprida's Avatar
so with the LE2 and a 50 shot?...where will i be?
Old Oct 17, 2010 | 10:11 PM
RamAir95TA's Avatar
A 50 shot is laughable. Go with the AI 200cc's and a 150-shot and you'll be smoking. But you are limiting yourself by not changing the gears (btw, what transmission?). The more details the better.
Old Oct 17, 2010 | 10:46 PM
jdelaprida's Avatar
I'm probably going to change me gears to 3.73s...i would do 4.11s but in the summer i want to be able to go down the shore on the highway and not be at 3000rpms.
and 4l60e, i rebuilding it this spring.
Old Oct 17, 2010 | 10:57 PM
jdelaprida's Avatar
On my camaro now i have a cold air intake, ordering the slp lm2 tuesday, got a msd coil in my garage, spring time when I'm rebuilting my trans, thats when ill probably buy the 3.73 gears. Otherwise after i do that ill probably get a nos system, and the LE2 or AI 200cc
Old Oct 18, 2010 | 06:19 AM
Procharged94Lt1's Avatar
Nitrous when done safely and correct power levels isn't as bad as some people make it out to be. The problem is people that try to run a 250 shot on a $400 kit on their Neon and expect it to live.
Consider dropping a grand on a good quality nitrous kit with all the proper safety measures good heads and cam package and you will have a screamer compared to what you are used too...
Old Oct 18, 2010 | 08:34 PM
jdelaprida's Avatar
Are you guys use stock pzm's or are you reflashing?
Old Oct 18, 2010 | 08:42 PM
RamAir95TA's Avatar
Stock PCM programmed as needed. "Reflashing" is just reprogramming the stock PCM for whatever you need.
Old Oct 18, 2010 | 08:46 PM
jdelaprida's Avatar
where do you send your pcm to get reflashed or programmed?
Old Oct 18, 2010 | 08:50 PM
RamAir95TA's Avatar
I use www.pcmforless.com and have been for the last 10 years. There are several other programmers available though...
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
