383 Stroker Kit Help Please
Old Jul 20, 2011 | 01:59 PM
joshmullins8's Avatar
Okay Im sick of not being able to drive my camaro, think I spun a rod bearing back in december so I pulled it off the road, long story short, its time for a 383 stroker, what do I need that I dont already have(by what you read below) what would you recomend, Im not a millionaire so Im not trying to go all out here but I want it done right, I plan on having a local shop JB's machine shop do my work(any suggestions or bad reps about the place please tell me), what crankshaft,rods,bearings,pistons whatever needed would you recomend to me? Thinking of doing a six speed swap while Im at it, what you think?
Old Jul 20, 2011 | 04:44 PM
Guest47904's Avatar
Guest
Buy a partial. If you do it the other way, you will be sorry in the end
http://www.golenengineservice.com/en...n-short-block/
Go ahead and price out the parts, the labor and the head ache of building it from scratch. It's a cheaper alternative. Don't care what a shop says, they won't stand behind a failure. Never heard one doing it accept maybe Jasper.
http://www.victoryracingengines.com/...TX&BLOCK=SHORT
The clutches in these vehicles are a nightmare due to such a short throw, best to stay away.
Old Jul 20, 2011 | 05:27 PM
dennis5374's Avatar
Re: 383 Stroker Kit Help Please
Why a 383 just curious? Looking for tq? 355 is cheaper ime because of much less machining of the block and possibility of reusing stock crank.
Old Jul 20, 2011 | 06:12 PM
Procharged94Lt1's Avatar
Re: Buy a partial. If you do it the other way, you will be sorry in the end
I agree with above, except the clutch- I don't have a problem with mine..its really touchy with the Spec 4 clutch in it, but its doable.
FYI- a decent crank will run you $800+, rods $500+, pistons $500+, bearings/gaskets/plugs $250- plus probably another $1500-2k in machine shop labor. After doing it myself I would recommend getting a short block- its a lot easier to do without having to try and figure out all the parts and make sure everything is compatible. I bought parts as I had money, then put it all together.
Old Jul 20, 2011 | 06:56 PM
RamAir95TA's Avatar
Doing a 383 probably won't be worth your while unless you plan on significantly upgrading the cylinder heads, cam, and valvetrain. A close-to-stock forged 355 is probably more in your ballpark.
Old Jul 21, 2011 | 06:44 PM
Thanks for the replies guys I really appreciate it, Ive already had a 355 ran good but I want something that stands out I want something that is really gonna go and I know you can do it with a 355 but if I spun a rod bearing then Im probabaly gonna have to reoplace my crank etc so I thought I might as well go 383 while Im at it. Any part numbers you can recommend, Im really bad at knowing whats conmpatible with what.
Old Jul 21, 2011 | 09:57 PM
RamAir95TA's Avatar
I would start by having a local machine-shop price everything out for you. Let them spec the parts.
OR, AI provides a few matched 383 kits. Might want to check them out.
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
