383 stroker cheap!
383 stroker cheap!
http://cgi.ebay.com/ebaymotors/LT1-S...spagenameZWDVWHow can a stroker be built this cheap?? Seems like an excellant deal for someone on a budget. Opinions please.
whoops! http://cgi.ebay.com/ebaymotors/LT1-S...spagenameZWDVW Here we go.
depends on what kind of power your gonna produce.... and if your planning on spraying or boosting FORGET IT...look at the components...ive got roughly 2000 in my shortblock and its mid level but definately better than that
i wouldn't buy it. i would rather save and buy an all forged short block. they estimate 430 horsepower with matching components. you can make 390ish on a cam only 350 ci lt1 and full full bolt ons. save your money bro.
The power a motor puts out is relative, the cubes have more potential, you have to use the potential.
Can I see the 390ish car or graph maybe? seems a bit high.
If your going to put all your components on that short block then it is reasonable but I personally would upgrade the pistons. If your starting with the short block and you have to purchase all the components to make it a running motor then your talking 5 to 6 grand total. All the little stuff adds up fast like cam, heads, rockers, lifters, timing set, ect.
So you have not had it dynoed yet?
