383 stroker build up suggestions
Old Apr 22, 2003 | 08:46 PM
set4lifenj's Avatar
My 95 LT1 block is going to the machine shop this weekend. The machinist is doing 4340 crank(not sure of brand) 4340 h beam rods, JE pistons I think 9.1 compression and sealed power rings. Basicaly i wanted a quote and wasnt sure which route i wanted to take NA or SC. I said probably a SC with 10psi or so. I told him i wanted it to handle 500hp.
I have a budget of 10g+ for this project. Im looking for suggestions. My goal now is 600hp to the rear wheels. If i can do it cheaper Im all for it (supercharged)
I guess the advice im looking for is on the components.
I have my eyes on a set of AFR 220cc heads, and a LT4 intake. Im uncertain on which cam to do, injector size or throttle body, which PCM or DFI? let along which SC.
Im sure there are few people here that has done this... would you mind sharing your info...
thanks
as for a car, I haven't decided what its going in
btw im looking to make this streetable... not an everyday car but a weekend warrior
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Rde Bandit
Mar 21, 2015 10:17 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
