383 strocker: what cam to use?
Old Aug 20, 2004 | 02:41 PM
  #16
Black_95Formula's Avatar
Re: 383 strocker: what cam to use?
Originally Posted by TQdrivenws6
...and Comp R lifters.
Hey I was planning to pick up a set of Comp R lifters for my setup. Would that be overkill?
Old Aug 20, 2004 | 02:52 PM
  #17
TQdrivenws6's Avatar
No, just make sure that you set them at 0 lash. They will hang the valves open with any preload. There have been many threads on this recently. My cam doesn't require them, so I went with a stock replacement lifter kit from GM to avoid the hassle.
Old Aug 20, 2004 | 03:39 PM
  #18
lethalz's Avatar
You get the specs on those cams when you pay for them. The LE2 is roughly the size of the 847, but will make more overall tq plus more peak hp. The LE3 is getting to be very large, so large it requires the comp 977 spring kit and Comp R lifters.
EDIT: yes, LE stands for Lloyd Elliot. The cams are custom ground to match his heads by Joe Overton.
is there any site or home page to contact elliot by internet
Old Aug 20, 2004 | 04:13 PM
  #19
nighttrain66@msn.com
drptop70ss
Mar 26, 2015 01:50 AM
transam_388
Mar 15, 2015 11:53 AM
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Nov 20, 2014 06:03 PM
