383 should i go 4-bolt?
Old Jan 20, 2006 | 05:02 PM
Black6spdZ's Avatar
I am goning to be building a forged 383 and was wondering if i really need to splay the main caps? I know that it will help make the bottom end stronger but is it that necessary? I am going to be running an eagle crank, h beams, srp pistons, gm 847, ported heads and intake. And there is a possibility of a little nitrous. Would i be "safe" on a 2 bolt block because it is going to be like an extra 500 to splay the main caps.
Thanks Scott
Old Jan 20, 2006 | 05:46 PM
BlackScreaminMachine's Avatar
Re: 383 should i go 4-bolt?
Any job, big or small, do it right, or not at all.
Since its going to be forged, I would spluge and do it. Power is addictive.
Old Jan 20, 2006 | 05:52 PM
n20fed's Avatar
I would definatley do 4 bolt. I'll try to post some pics of the disaster I had with a similar setup on a 355. How does 4 rods bearings, 2 main bearings and, 3 damaged caps sound?
Old Jan 20, 2006 | 05:55 PM
Black6spdZ's Avatar
sounds like hell, thats what i am afraid of, i am going to end up wayyyyy over what i planned to spend but such as life i guess. This started out as a head and cam swap gone bad when i found out i had stock internals.
Scott
Old Jan 20, 2006 | 06:36 PM
IrocSS85's Avatar
yeah, I was very fortunate and I actually had a stock 4 bolt block but Id def. do it. the rest will be forged so your gonna want to put some nitrous to it later, no point to leave a weak point in there at this point ya know?
Old Jan 20, 2006 | 06:48 PM
texasTA's Avatar
I would go splayed also. Like was stated before, do it right the first time. I just so happen to have a fully-forged 383 shortblock for sale. If you are interested, I have 4600.00 into it with machine work, assembly and parts that I am trying to sell for 3800.00 It is setup to handle a 400 shot of nitrous, so in other words she is pretty stout.
let me know if interested.
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
