IAT relocate and Opti Vent to CAI?!---
Old Jan 18, 2006 | 04:21 PM
AlwaysCode390's Avatar
Lightbulb IAT relocate and Opti Vent to CAI?!---
I got a vortec elbow and the IAT doesnt come close to "threading" into the hole they give you, lol....AND there is no opti vent hole. Instead of drilling in the aluminum can I just drill into the K&N FIPK CAI that I have and remount the two things? I will just use the stock rubber boot for the IAT and just plug the Vent into the drill hole right? I will plug the threaded hole in the elbow too. If I leave the vent exposed is that ok too (not plugged into anything just zip tied down? THANKS!!!---
Old Jan 18, 2006 | 04:25 PM
Digital Designs's Avatar
Re: IAT relocate and Opti Vent to CAI?!---
you can relocate the IAT anywhere on the intake but the opti tube must be located after the MAF so that it accounts for the pressure difference and you wont develop a stumble
Old Jan 18, 2006 | 05:13 PM
OBE1 95Z28's Avatar
You need to use a die and cut threads into the IAT plastic housing prior to trying to thread the IAT into the metal elbow. Slowly rock the die back and forth to remove the "meat".
Old Jan 20, 2006 | 01:14 PM
Does a hardware store sell a die that big?!---
Old Jan 20, 2006 | 01:24 PM
yes, it is only 1/2 - 5/8
Old Jan 20, 2006 | 01:41 PM
1racerdude's Avatar
For the Opti ya can put a small filter on it and lay it by the valve covers. A real small inline gas filter for a lawn mower will work and not look out of place or GM makes small vacuum line filters.
Old Jan 20, 2006 | 06:52 PM
Perfect, thanks guys you helped ALOT---
Old Jan 20, 2006 | 07:45 PM
OBE1 95Z28's Avatar
Using a filter to the atmosphere instead of the intake track (after the MAF) is creating a vacuum leak as it's providing unmetered air to the engine. Granted it's a small leak but why have any leaks when you can tap into the intake track and hook the opti feed line up correctly.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
