383 setup with Le2 PKG good for everyday use
Old Feb 10, 2006 | 05:06 PM
playa7970's Avatar
i was in the process of building my z28 i just ordered my le2 setup and just recieved the cam i was wondering with the 383 comp short block and le2 setup will be alright for an everyday driver some input would be great thanks
Old Feb 10, 2006 | 06:07 PM
97HUGGER's Avatar
Re: 383 setup with Le2 PKG good for everyday use
I have a 383 with LE2 heads and a CC503 cam and the motor made 468 hp @ 5700rpms and 484tq @ 4200rpm - these numbers where on an engine dyno and not at the rear wheels but for an emissions legal setup its not too bad. When it was tested on the engine dyno the fuel injection and LT1 intake was not used so it was running on a holley 650 carb and bowtie intake with 1 5/8 headers stepped up to 1 3/4 - I have short tube headers on my car for emissions purposes and I would guess they are probably costing me 30hp. As far as an everyday driver it is no problem. I don't know if this info helps you as the LE2 cam is probably much larger and I'm sure it will have more overlap than mine. The nice thing about a smaller cam is the low end torque for daily driving but the larger cams definately make up for it in the higher rpm, it just depends on what you can live with and what your goals are.
Old Feb 10, 2006 | 07:07 PM
ken9c1SS's Avatar
it will be fine
Old Feb 10, 2006 | 07:23 PM
97 RedSS's Avatar
It will be great...I used to drive mine everyday before I got a cheap beater to keep the miles off the SS...I was getting around 17-18 mpg also..youll love the low-end trque and how it pulls uptop also..if you have it dyno tuned it will yield the best results..
Cody
Old Feb 10, 2006 | 07:26 PM
playa7970's Avatar
Thanks for the reply cant wait till its done one more question what do i have to do to my tranny to handle that kinda power and say i run a 150 shot to it ? who should i go to for parts because i had some baddd experiences with local shops its an a4 remember everyday driver thanks!
Old Feb 11, 2006 | 10:52 AM
GREAT_WHITE's Avatar
Cody
YOU HARDLY DROVE THE SS WHEEN ITS ALL YOU HAD ,, NOW I NEVER SEE IT,,,,BRING IT BACK TO L-TOWN SO I CAN BUST YO ***
KRIS
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
