383 run really bad
Old Jun 25, 2009 | 05:18 PM
  #16
Before ripping anything apart, determine if your engine was "externally" balanced (needs the weight on the flywheel/flexplate), or "internally" balanced (does not need the weight on the flywheel/flexplate).
Old Jun 25, 2009 | 10:24 PM
  #17
spike30th's Avatar
I tryed talking to the guy I bought the motor off of I asked him is the motor externally or internally balanced and he keeps saying yeah the motor is balanced which of course dosent answer my question. So he is no help. This is what I know about the internals it's a eagle rotating assembly. Eagle forged crank I have reciept here that he had the crank balanced.I have no idea how I can tell if this motor is externally or internally balanced. The vibration deff feels like it is coming from the clutch area and feels like something is just out of balance.
Old Jun 26, 2009 | 01:52 AM
  #18
spike30th's Avatar
this is the flywheel that the previous owner was running on the motor before i bought the motor.its a fidenzia flywheel.can anybody tell if it has been zero balanced? I cant tell if theres any weights on it
Old Jun 26, 2009 | 08:24 AM
  #19
WS Sick's Avatar
If you have the receipt just call the shop that did the work and ask them how they balanced it.
Old Jun 26, 2009 | 10:56 AM
  #20
Nostang 96z's Avatar
Most likely an internal balance as most shops will internal balance with an aftermarket crank and flywheel for a performance build. I do not see any weights on the flywheel in the picture. If you can unbolt the weight from the flywheel you have now, I would just do that and see if that fixes the issue.
Old Jun 26, 2009 | 11:12 AM
  #21
spike30th's Avatar
Yeah I don't see any weights either. I am just going to remove the weights and see what happens
Old Jun 26, 2009 | 11:16 AM
  #22
ssclone's Avatar
if its anything like sbc 1pc seal crank, the weight is built into the flywheel. you cant remove it.
you sure your firing order is correct?
aaron
Old Jun 26, 2009 | 11:53 AM
  #23
spike30th's Avatar
I just called spec up and the guy said the weight is bolted down on there flywheels.
Old Jun 26, 2009 | 02:36 PM
  #24
crash4cyl's Avatar
I'd call the shop that balanced it and then remove the weight if needed, then you should be good to go. If nothing else get the fidanza flywheel resurfaced, and get a new clutch to go with it and slap it in and run.....just my $.02
Old Jun 26, 2009 | 07:34 PM
  #25
spike30th's Avatar
Well I took off the weight on the flywheel took about 1/2 hour and everything is good now no vibration. Thank you every one I don't know what I would do with out this site
Old Jun 27, 2009 | 10:03 AM
  #26
The SRZ's Avatar
Glad to hear you're good to go! Go have some fun now w/ that sucker now.
Old Jun 27, 2009 | 03:55 PM
  #27
spike30th's Avatar
haha I deff am.
D1SC383LT4
Jan 26, 2015 01:41 PM
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Collector Car
Dec 17, 2014 01:12 PM
