383 Qeustion
Old Jul 10, 2006 | 03:39 PM
LT1CST's Avatar
383 Qeustion
I just disassembled my 355 LT1. IM going to do a 383 rebuild. However Money is super tight and Im on a budget. Will this work? Using my .30 over Forged probed pistons and my stock 5.7 rods. Can I use a 3.75 Crank (383) with the same rods and pistons that I used for my 355?
CHris
Also will my Cam clear the stroker motor. Its a 224/236 XE cam LSa 114
Old Jul 10, 2006 | 03:45 PM
predator's Avatar
Re: 383 Qeustion
you can use the 5.7 rods but you need to get the pistons made for the 5.7 rods and the 375 stroke your compression heigth will be to high prolly out the bore.....is it a small base circle cam
Old Jul 10, 2006 | 07:04 PM
LT1CST's Avatar
Re: 383 Qeustion
iM NOT SURE ITS A 224/236 XE CAM FROM COMBINATION MOTORSPORTS IN VEGAS. THE LSA IS 114
ILL PROLLY JUST GET A NEW ROTATING ASSEMBLY
CHRIS
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
