383 Oil Pumps: Melling Standard vs Select
Old May 24, 2010 | 08:14 PM
Bersaglieri's Avatar
Well the time has come to buy an oil pump for my 383 stroker motor. Just for reference I have a Milodon 30909 oil pan. I have a used M55A lying around, but I don't want to risk running a used one in this motor, especially since they don't cost much for how critical they are to engine operation.
So I called my machinist to ask his opinion on oil pumps. He recommended a high volume melling select oil pump instead of the standard M55 ones. I asked him why the select and he said the case is stronger, as are the gears and oil pump drive shaft. I asked about the HV part and he said that's what he usually uses, although he mostly does circle track motors. Seemed like a pretty good reason, but I figured I'd ask around here for opinions.
Most folks seem to use the standard M55 series with no problems, but if it's worth the extra money, I have no problem stepping up to a better pump. It's one of the most important parts of the motor. I'm going to run a HR cam going to 7000rpm, but may move to a solid roller someday. It's a street/strip car. I'll post up all the bearing clearance specs in a few days when I am done blueprinting the motor, but so far the mains seem tight.
My buddy whom I'm building the motor with basically said High Volume = Circle track, High Pressure = drag race.
So basically, is the select series from Melling worth the extra money? Is there any good reason why I shouldn't just run a standard volume higher pressure oil pump, pending bearing clearances...
-Dustin-
Old May 24, 2010 | 08:17 PM
MikeGyver's Avatar
It's such a cheap and crucial part. Get the Select.
Old May 24, 2010 | 10:17 PM
-Dustin-
10554 Melling Select. SV with the pink 70# spring. Unless you have a serious reason with bearing clearanced for an HV pump, you don't need it. All it does is put extra stress and wear on the oil pump drive gear (hint: premature gear failure and no oil pressure) and take more HP to turn it.
Old May 24, 2010 | 10:52 PM
Dave1980's Avatar
I wound up going 10% overdriven on my build. I was confused at getting the right combo of pump/pickup to work with my Canton 242T pan at the time. I knew I didnt want to get 20% overdriven.
The other non select melling casting scared me away, with the note saying it was not for performance use.
I would listen to shoebox about getting anything closest to stock form with the select heavier duty casting.
A lot of guys have cracked the drive gear on top. (it seems to be a point of stress in relation to HV pumps.) I wound up making a backing plate to reinforce the area. I have my fingers crossed that things will work ok. You can really eff up your motor if you drive breaks, and gets no contact.
Old May 24, 2010 | 11:14 PM
RamAir95TA's Avatar
x2 with the 10554. It also included a hardened OP drive shaft.
Old May 24, 2010 | 11:45 PM
Thanks guys, I figured the 10554 was the one to go with, I mentioned it to my machinist and he was it was the anti-cavitation version which wasnt necessary But I saw a few on here using it.
I have a Milodon pickup that was welded to the old M55A, but it looks like this http://www.summitracing.com/parts/MOR-24360/ is the only thing Summit has in the 8.25" pan depth 3/4" size as a replacement.
-Dustin-
KYWes
Apr 15, 2015 07:11 PM
Rde Bandit
Mar 21, 2015 10:17 PM
transam_388
Mar 15, 2015 11:53 AM
Jan 23, 2015 01:13 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
