383 LT1's...a few questions...
Old May 17, 2004 | 07:13 PM
tamatt27's Avatar
Can a 383 be used with stock F-Body heads temporarily and not cause any problems? I've heard that lightweight flywheels can cause idling problems on the street. Is this true? Also which cam should I go with? It'll be mostly for cruising and everyday driving GM 847 ot CC306? It'll be a daily driver, so MPG is an issue, hence the T56.
BTW this is all going in my '88 T/A.
Old May 18, 2004 | 08:04 AM
Gripenfelter's Avatar
Well if you do a cam and don't do heads the motor won't breathe so you won't be making any real horsepower. If this isn't an issue, go nuts!
Also drivability is fine with a GM 847 in a 383.
I have a cam similar to that and its perfect for the 383.
Old May 18, 2004 | 10:34 AM
RiceETR96's Avatar
You can use the stock casting but like Grip said, its not gonna make any decent power.
Old May 18, 2004 | 05:00 PM
tamatt27's Avatar
Well I onlt plan on using them to break in the motor, and until I get enought $$ for some AFR's. Does anyone know about the flywheel thing?
cheapchevy
Apr 8, 2015 08:48 PM
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
