383/LE TFS combo
Re: 383/LE TFS combo
Strokerace is right. Getting the valve train setup is work. I am a prime example of that. I am in the process of redoing my valve train due to a colapsed lifter and eating guide plates. I went with the Isky adj. guide plates. You can set them where you want them and once they are set tack them with a weldwer and you are set. Good luck.
HVY SS
HVY SS
Originally Posted by SStrokerAce
gettin the right PR length mike take a little work... you still looking at some Morels? We could meet up to get that all settled out for ya.
Bret
Bret
Originally Posted by Josh'95Z28conv
What makes it "take a little work"? Can you just throw it together and measure, or do you actually need one solid lifter to mock it up and measure? Im going to be doing this as soon as I get my LE3 setup (still a few weeks out on them from Lloyd).
It takes some work to get the pattern as narrow as possible and the sweep as close to center as possible. Ya will need an adjustable PR also.
3/8 bolt?
Nah you gotta turn down a piece of 5/8 ground rod and make it right within a .005" for a checking lifter!!!! ;-)
It's nice to have a machine shop!
Bret
Bret
lol.....
I'm just going to have the screw machine shop make me a bunch so I can have a ton laying around here for guys to check with.
Bret
Bret
Seriously...
3/8 bolt?
Bret
Bret
lol.....
Bret
Bret
We do it the old fashion way,we make it.
Originally Posted by 97WS6NY
295@600 297@650 and yeah the cam is pretty large
Well 270/276@50 on a 108+4 .806 net lift is healthy.(street grind?????)
Don't know what ya are calling healthy though.
That one is probably in the 250 range.
The TFS guide plates align everything like they should be. The Comps are just a lil different.
I would stick with a 5/16 PR, just get a Comp Hi tech series the right length.
The TFS heads have a small hole for the PR to travel through and a 3/8 would probably contact the head from just eye balling it.
Lloyd
Lloyd
Originally Posted by 1racerdude
Don't have that luxury.
Bret
