383 kit
Old 11-20-2003, 01:08 PM
Balls's Avatar
383 kit
Does anybody know the spec on this kit?
"Super Street" 383 stroker kit from PAW (Performance Automotive Warehouse) that includes new .30 over pistons, custom ground crank shaft, new bearings, rings, connecting rods, seals and freeze plugs.
like what material the rings are and if the crank shaft is strong
I'm also curious about this whole process I believe I need a rebuild and if i'm gonna do that. I want to go .030 overbore
I'm also curious about head work would a mild port match up good w/ a 383 bottom or would more agressive porting be necessary
I really don't know much so if you could be as descriptive and as helpfull as possible it'd be apprecaited.
basically I'd like help building my complete engine if you didn't get that impression in the first place
Balls is offline
Old 11-20-2003, 03:41 PM
Balls's Avatar
Sorry about leaving out details
the kit would go into a 95 LT1 in a z28
everything else is stock so far
Balls is offline
Old 11-20-2003, 08:33 PM
Advanced Tech Moderator
kmook's Avatar
Hey bud,
The only way someone is going to be able to tell you how good the parts are are by knowing what spacific parts come in that kit... So best bet would probably be to call them and get spacifics on the parts that are included.
Though general buildup and help should be discussed in a generation spacific forum. Moving to Lt1 Tech, thanks.
kmook is offline
10-31-2016 11:09 AM
D1SC383LT4
01-01-2016 01:56 PM
Drtryder
04-22-2015 04:17 PM
transam_388
03-15-2015 11:53 AM
D1SC383LT4
01-26-2015 01:41 PM
Quick Reply: 383 kit
