383 help
Old Aug 8, 2011 | 10:27 PM
importkiller94's Avatar
383 help
I put in 4 bolt splayed caps and now the oil dipstick doesn't fit, I tried bending it to make it fit and now its ****ed, is there another option? And also its a 94 obd1 but I had to use the obd2 timingcover and opti do to the timing set I used, do I have to tune the computer for that or will it work without the tune. I forgot to let pcm for less know
Old Aug 9, 2011 | 05:25 AM
RamAir95TA's Avatar
Re: 383 help
Trim the dipstick tube and/or indicator as necessary. Mine only protrudes into the block far enough to see the full mark and change - that's it.
The PCM doesn't care which cover you use. Just make sure the CPS sensor hole is blocked off.
Old Aug 9, 2011 | 07:42 AM
Re: 383 help
So cut the tube instead of bending it, now the dipstick is still going to hit the cap and flex straight down instead of at an angle where it is supposed to be, will this change where the actual full mark will be? Someone told me I should fill the pan with the exact amount of oil it should take when empty and then etched a new mark on the dipstick. Does anyone know how many quarts exactly I should use to fill it when empty
Old Aug 9, 2011 | 08:58 AM
RamAir95TA's Avatar
Re: 383 help
Cut the indicator just short of where it hits the cap.
Old Aug 9, 2011 | 09:31 AM
Re: 383 help
Cool thanks a lot for the help
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
