383 help
Old May 2, 2004 | 10:55 AM
1984camaroz28's Avatar
383 help
I boght a NOS kit for my car now. I plan on running it on the stock LT1 to test its limits befor i do the stroker motor. I bought a stroker kit a few months back but it only cast crank and hyp. Pistons ( 11 to 1). How much NOS can they handle. I plan on running the CC306 cam. Trick flow heads. Where whould be the best place to buy a Forged 383 kit
Old May 2, 2004 | 02:55 PM
rskrause's Avatar
Moderator
I wouldn't worry to much about the crank if you plan to run a 150-250hp shot. But I wouldn't consider generic hypereutectic pistons. You need a pison designed for nitrous. KB makes some hyper pistons designed for nitrous, and there lightweight forged pistons that are emphatically not designed to run with nitrous. So it isn't completely a matter of forged vs. hypereutectic vs. whatever.
Anyway, the best pistons are made by JE/SRP, Ross, Diamond, etc. There are a lot of choices. The most mportant thing is to get a piston designed for nitrous. It will have a thicker, stronger crown, beeed up pin boss, thick ring lands. Also avoid light weight wrist pins with N2O. There are other engine building "tricks" for N2O that I could go into if you are interested.
Rich Krause
Old May 2, 2004 | 03:16 PM
Ok thanks I still need a 5.7 rod what do u think i should go with. Any links to the KB nos pistons
Old May 2, 2004 | 03:22 PM
im looking for 11 to 1 with a 64 cc head.... im having a hard time finding a piston now.....
Old May 2, 2004 | 04:24 PM
rskrause's Avatar
Moderator
www.kb-silvolite.com/
www.jepistons.com/
www.rosspistons.com/
Rich
I really don't know the low end rods very well. I think Scat makes a moderate price forged rod.
Rich Krause
Old May 2, 2004 | 05:14 PM
64-11.2 to 1 Do u think this will be ok on pump 93 any maybe swing 89 or no
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
