383 guys...bearing question
Old Jul 26, 2004 | 12:51 PM
RealQuick's Avatar
Guys with strokers, I need rod and main bearings for my 383 (cola crank and eagle h beam rods). Are these the right P/N's for the Clevitte bearings:
rods are cb-663 p
Mains are MS-909 P
Old Jul 26, 2004 | 12:53 PM
Dave C. '97 Z28's Avatar
Re: 383 guys...bearing question
You should be measuring that. You have to select the bearings within 0.0005" - 0.001".
You need to mike those journals to see what size you need, then set the bearing clearance based on what Cola recommends. Normally it's between 0.002 and 0.003 for mains and 0.0015-0.0025 for rods on a motor used for racing, but your oil pressure drops the looser you run them.
It's not trivial.
-Dave C. '97 Z28
Old Jul 26, 2004 | 01:12 PM
RealQuick's Avatar
It's not trivial.
-Dave C. '97 Z28
Cool. Thanks for the info.
D1SC383LT4
Jan 1, 2016 01:56 PM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
