383 FINALLY finished *PICS*
Old Nov 17, 2005 | 05:32 PM
NVetro's Avatar
Well all, its been a long and expensive journey but she is finally DONE! For those who dont know, its a 383 going into my 1994 Trans AM M6:
Block: Originaly 1996 Caprice Police Car 5.7L LT1 w/ 86,000 miles, bored .030 over, decked line honed, hot tanked 1000 times, and converted to 4 bolt splayed main with 3 center program caps, Clevite "H" Series Bearrings all around, block also painted jet black.
Crank: Callies Dragon Slayer 3.75" Forged
Rods: Callies Compstar 5.7" Forged
Pistons: Custom JE -16cc, forged 2816 alloy w/ nitrous pins and Hell-Fire Rings.
Heads: LT1 Alluminum Casting ported by Total Engine Airflow, flowing 276in/248exh @ .600 lift, 2.00" intake valves and 1.56" Exhaust valves (Exhaust flowed with a pipe), bolted up with Cometic MLS .040 Head Gaskets.
Cam: Custom Bret Bauer 23x/24x
Valvetrain: Comp Cams Pro Mag 1.6 NSA RR, Comp Cams 'R' Lifters, PEP Springs, Titanium Locks, Comp Cams Chromemoly 7.2" push rods
Intake Manifold: Stock LT1 ported by Lloyd Elliot and enlarged to fit the Holly 58mm tb.
MISC
Canton Oil Pan
ATI Super Dampener
Holly 58mm TB
Aeromotive AFPR
Delphi 42lbs injectors
Chrome Valve Covers
Coyles Double Roller Timing Chain
Converting to Vented Opti
CSI Eletric WP
Deleting HVAC
Converting to new style Radiator hose design
Intake Manifold and Accessory bracket powder coated jet black
Etc etc etc etc.........
And here she is........lots of jet black powdercoat and chrome
http://www.webideas.net/94transam/38...r/DSC00091.JPG
http://www.webideas.net/94transam/38...r/DSC00089.JPG
http://www.webideas.net/94transam/38...r/DSC00093.JPG
http://www.webideas.net/94transam/38...r/DSC00102.JPG
ENJOY, questions welcomed.
Old Nov 17, 2005 | 05:55 PM
Dave '97 Z28 M6's Avatar
Re: 383 FINALLY finished *PICS*
That's a thing of beauty!
I remember that my 383 looked almost that nice a few months ago... it looks dirty and used now
Old Nov 17, 2005 | 06:00 PM
bdc95ta's Avatar
beautiful! How much does something that sweet set ya back.
-b
Old Nov 17, 2005 | 06:03 PM
luckyou03's Avatar
wow! nice job!!!!
Old Nov 17, 2005 | 06:04 PM
Cmr0z28's Avatar
Goals?
Old Nov 17, 2005 | 06:54 PM
ejfagala's Avatar
You are going to love that set up. I will be interested to see how Brets cam works with it. I have no idea of what your goals where but you built one hell of a great daily driver that will make great power.
Old Nov 17, 2005 | 07:38 PM
ZBLKHELLRZR's Avatar
Looks great. What made you go w/ Hellfire rings? That's a harder steel ring isn't it?
Old Nov 17, 2005 | 08:16 PM
NVetro's Avatar
bdc95ta: WAYYY to much $$
Cmr0z28: Hoping for 425rwhp-450rwhp NA somewhere around there. On top of that I am going to be spraying about a 150 shot through a NX wet kit. So lets say 575rwhp-600rwhp on the N2O.
ZBLKHELLRZR: Went with the hell fire rings becuase they are a better ring designed for n2o and boost applications, in the future, I will be slaping a set of larger CC heads on there and dropin the compression down and boosting and spraying it hopefully, but thats WAYYY down the road. Piston to wall clearence and ring gaping is all setup for this future setup already.
Old Nov 17, 2005 | 10:02 PM
Evil Eric's Avatar
Wow, congradulations man that thing looks like a beast. Bet you cant wait to get in back in the ride
Old Nov 17, 2005 | 10:15 PM
TCAL95Z's Avatar
looks great!
Did you have to do anything to put that ATI dampner on? I have one for my 381
I've heard different things on the install.
How soon till the dyno/track?
Old Nov 17, 2005 | 10:37 PM
1racerdude's Avatar
Sweeeeeeett.
Nice job. Ya spent a lot of time on it.
Old Nov 18, 2005 | 12:21 AM
93 4mula's Avatar
Just curious but can you set our LT1's in fully assembled like that from the top?
Old Nov 18, 2005 | 12:55 AM
Fat_Boy's Avatar
Wow! That looks good and will be a beast for sure..the only thing I dont like(and its just me) is the wires running on top of the valvecovers..beats burning them though!
Old Nov 18, 2005 | 01:25 AM
lt11997's Avatar
Great looking engine!
The only thing I noticed is that you don't have the #5 and #7 sparg plug wires crossed. If you don't do this it can lead to inductive firing and can eventually burn a hole in those two cylinders.
Old Nov 18, 2005 | 01:01 PM
CANTONRACER's Avatar
Nice looking setup...
I am curious how your heads flow what they do on the exhaust side. That number seems about 40 cfm high and if you have a custom cam with those numbers in mind....I would concerned.
Where I am coming from is I run AFR 210's with the exhaust side really worked over with my heads running 1.620" valves and huge exhaust ports that flowed 232 @.600 and 251 @.700 with a pipe. My ports are big enough I cannot run normal Hooker LT's(just like yours) because the flange was 3/10's of inch to narrow.
Anyways, looks great.
