383 dyno numbers?
383 dyno numbers?
i just bought and installed a 383 from a friend. i put it on the dyno and want to compare with some like motors.
i was wondering how other 383's did. please, only post if you have:
383
11:1 CR (or near)
LT1 heads (not LT4 or AFR)
M6
i made 411rwhp and 418ft-lbs (SAE correction. please post if your CF is different). my stock fuel pump cannot make any more. my AF was between 13.0:1-13.6:1 all after 3400rpms. i am sure i can bring some numbers up and flatten the TQ curve with more fuel (12.5 since the car is not moving on a dyno). here is my graph.
how do some others with like motors compare and what kind of gains do you think i will see with more fuel?
please, list your cam, compression, , correction factor, and gears so i know what i am comparing to! thanks.
383
11:1 CR (or near)
M6
Joe Brodman
Jul 24, 2002 05:24 AM
