383 Cam Question
Old Feb 21, 2009 | 12:37 PM
87bandit's Avatar
383 Cam Question
Just wondering if anyone has used this cam:
Comp XE 236 / 242, .520 / .540 112 LSA
or one similar to it in a 383. if so what are your impressions of it? power/e.t. numbers? where do you shift it at? I understand most people will say "go custom" but I was just using this cam as a base since I'm looking at it along with AI and LE grinds in a similar size
Old Feb 21, 2009 | 01:24 PM
PHINES LT1's Avatar
i'm running a cam with same duration but a little higher lift, and on a 110 LSA. stock heads/shortblock. shifting around 6400 times in sig. should work reall well in a built 383
Old Feb 21, 2009 | 09:10 PM
87bandit's Avatar
looks like some good times for stock heads thanks for the info
anyone else with more opinions?
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
Queens94z28
Nov 20, 2014 06:03 PM
