383 block prep
Old Feb 14, 2004 | 06:58 AM
fastcamz28's Avatar
383 block prep
Exactly what machine work needs to be done to prepare a LT1 bare block for a 383 rotating assembly? Thanks!
Old Feb 14, 2004 | 07:12 AM
S.J.S.'s Avatar
Well they'll hot tank it....then they'll bore and hone it....then they'll clearance it. I'm sure I'm forgetting a few things but its 3am here, sorry.
Old Feb 14, 2004 | 08:22 AM
rskrause's Avatar
Moderator
Why are you asking? Curiousity, or do want a DIY guide?
Rich Krause
Old Feb 14, 2004 | 09:23 AM
SStrokerAce's Avatar
Re: 383 block prep
How much power? How well do you want it done?
IMHO The list is:
Magnaflux and Inspect for Cracks
Oil Prep
Clean (either sand, shot or chemical)
Clearance for 383 or 396
Paint
Install 4 Bolt Main Caps
Line Bore and Hone
Bore and TQ Plate Hone (need pistons for this step)
Zero Deck
You can get away with less but that's the standard treatment.
Bret
Old Feb 14, 2004 | 01:30 PM
fastcamz28's Avatar
Rich Krause
When I talk to a builder or investigate the purchase of a prepped block, I want to know exactly what to ask about/ look for. I want to be a well-informed consumer!
Thanks!
Old Feb 14, 2004 | 05:16 PM
With engine builders you really want to know how good of machining they do and the tolerances they look for. How they go about what they do is also important. How they measure piston to wall clearance, how they measure deck height for zero decking the block.
I should also have included a final cleaning and cam bearing install in that last post.
Bret
Devinfoote87
Feb 12, 2016 03:21 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
MikeWhitener
Aug 2, 2015 06:17 PM
camaro02DK
Jul 5, 2015 09:04 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
