383 block prep
Re: 383 block prep
Originally posted by fastcamz28
Exactly what machine work needs to be done to prepare a LT1 bare block for a 383 rotating assembly? Thanks!
IMHO The list is:
Magnaflux and Inspect for Cracks
Oil Prep
Clean (either sand, shot or chemical)
Clearance for 383 or 396
Paint
Install 4 Bolt Main Caps
Line Bore and Hone
Bore and TQ Plate Hone (need pistons for this step)
Zero Deck
You can get away with less but that's the standard treatment.
Bret
Originally posted by rskrause
Why are you asking? Curiousity, or do want a DIY guide?
Rich Krause
Rich Krause
When I talk to a builder or investigate the purchase of a prepped block, I want to know exactly what to ask about/ look for. I want to be a well-informed consumer!
Thanks!
With engine builders you really want to know how good of machining they do and the tolerances they look for. How they go about what they do is also important. How they measure piston to wall clearance, how they measure deck height for zero decking the block.
I should also have included a final cleaning and cam bearing install in that last post.
Bret
Bret
camaro02DK
Jul 5, 2015 09:04 AM
