383 almost done w/ PICS
Old Jul 21, 2006 | 06:29 PM
sleeperMULLET's Avatar
hey guys, almost done putting together my 383. I'm just waiting for injectors and flexplate bolts. One bolt hole for the passenger side headers is messed up and i need to get a tap so thats why the one header isn't on. And the Trick Flow heads don't have the same bolt holes as a stock head to mount the wire loom brackets so I just put them on top of the valve covers. Heres the list:
383cid Blueprinted and Balanced
Splayed 4 bolt mains
11cc dished SRP pistons
6" CAT H-beam rods
Eagle Forged Crank
205cc Trick Flow heads
CC306
Comp 1.6 narrow body roller rockers
Comp push rods
Melling 155HV
6qt Canton
SVO 42lb injectors, when they get here
CSR electric water pump
ATI SFI damper
Blaster coil
MSD 6AL box
Talyor 8.8 wires
PCMFORLESS tune
the rest of the mods for the car are:
TCI SFI flexplate
TCI 3000 stall T/C
built 4l60E
3.5" moser driveshaft
Moser 9" w/ 3.73s and Detroit locker
custom SFC
custom Panhard bat
boxed trailing arms
Walboro 255 intake feeding a A1000 external pump
-8 supply line with stock return line, i sure hope the fuel system works
and LT1 scanmaster
I'm sure i'm forgetting some other stuff, but I did everything on the engine except align bore and hone the mains and cylinders, and deck the heads and block, the machine shop got to do that. But i learned how to balance the rotating assembly, i ported and polished the heads and intake, and put everything together. I was in a engine building class so I had someone watching everything I did. Let me know what you guys think, and let me know if i need to change some parts to get this thing to run good. Thanks.
http://i78.photobucket.com/albums/j9...Picture006.jpg
http://i78.photobucket.com/albums/j9...Picture011.jpg
http://i78.photobucket.com/albums/j9...Picture010.jpg
http://i78.photobucket.com/albums/j9...Picture009.jpg
http://i78.photobucket.com/albums/j9...Picture008.jpg
http://i78.photobucket.com/albums/j9...Picture007.jpg
Old Jul 21, 2006 | 06:56 PM
bufmatmuslepants's Avatar
Re: 383 almost done w/ PICS
i am looking to build the same thing basically over the next couple years, good luck man. are you gonna strap it to a dyno or hit the track anytime soon with it?
Old Jul 21, 2006 | 07:02 PM
user 647483's Avatar
Lookin' good. Can't wait to see it in the car
Old Jul 21, 2006 | 07:44 PM
it will be in the car maybe next week, then after everything is broken in i will get track times. I have some Nitto 555 DRs but they don't hook up very well, so when i get some better tires i'm hoping for 11's maybe even 10's
Old Jul 21, 2006 | 09:20 PM
1racerdude's Avatar
All PUTTIE and SHINY.
Nice job.
Old Jul 21, 2006 | 09:26 PM
Stroked94z's Avatar
How much did you pay for that oil pan? All the ones I have seen have been really steep and I was just wondering where you got it from?
Old Jul 22, 2006 | 12:12 AM
got it on ebay, i think it was close to $300
Old Jul 22, 2006 | 10:45 PM
its all done now, i just have to put the tranny on and the wiring harness. i was getting a little restless so i wired up the 6AL box.
Also, do you guys think the alternator will cause any electrical interference with the spark plug wires being so close to it? there are a few pics of how close they are at the end.
Old Jul 22, 2006 | 10:48 PM
LenT1's Avatar
That holly looks so darn good...
Fastbird93
Apr 9, 2016 07:01 PM
Drtryder
Apr 22, 2015 04:17 PM
cheapchevy
Apr 8, 2015 08:48 PM
drptop70ss
Mar 26, 2015 01:50 AM
