383 or 355?
Nope my car just has a simply 12 bolter with Richmond 3.73 gears, it should hold up just as as my GTA is simply a rig for running back n forth to work with all summer long the 406 shouldn't harm it a bit . . .
If i was going for a Racing type setup under the GTA i would more then like run a chopped 14 bolt or Dana rear end possibly.
all tho the unit under my AMX would be my ideal choice in rear end's, 4.44:1 gears fully lock carrier, Rip's off 9.60-9.70's at over 140mph in 1/4 has 75K miles on it and still going strong. . .
Best run was 9.63@143mph got good launch only spun 10-15 feet 2.8? 60ft. . .
Worst run was 9.72@138mph really sucked spun tires right threw the 60ft 3.2?. . .
It's been year's since i have ran that car as fast cars take $$$
69' AMX:
AMC 390 Crossram, borgwarner T-10 4spd, 4.44 Gears, G60-14s Front N50-15s Rear cars is 1 of 53 built.
Mike
69' AMX:
Mike
I love when people say this stuff. I in no way had any money for nothing after my engine build. I bet your the guy who see's someone living in a 500k house with no swimming pool and is in debt up to there eyes then says "if they could afford a house they could of got a pool".
i snapped axle on stock rear end with stock power + new clutch
have 12 bolt in there now and a cam. although i havnt been to the track with the 12bolt with sticky tires yet
it sure "feels better" if that makes any sense
True that lack of traction sucks
stupid polyglass tires
, and yes The AMX is a manual transmission as well
and its all factory
Only Mod's i did was increase compression from 12.5:1 to 12.75:1 and re-jetted the carbs oh and the re-cured the spark, Other then that its a 100% factory Hurst AMX . . .
But the 9" rear end's i destroyed where all in truck's plain jane old truck's stripped 5 yokes broke 2 ring gear's and Blow 1 whole unit all over pavement plowing snow
Mike
and its all factory
. . .Only Mod's i did was increase compression from 12.5:1 to 12.75:1 and re-jetted the carbs oh and the re-cured the spark, Other then that its a 100% factory Hurst AMX . . .
Mike
I did a forged 355 a few years ago, and now wish I spent the extra cash to get the 383. From what I have researched, they will last the same amount of time, and it's the 396 that starts getting the cylinder walls a bit too thin. Just my 2 cents...
Yea, my racing will be limited also, between work an the 4500+ ft altitude it doesnt look good.
-Dustin-
