383 12 to 1 compression and a stock starter
Old Jan 23, 2007 | 06:24 PM
  #16
Loadre's Avatar
Originally Posted by marshall93z
Stocker was strong enough for bend a rod while cranking with some water in the cylider!
Join the club.
Old Jan 23, 2007 | 06:39 PM
  #17
cmroSS97's Avatar
My stocker cranks mimy 12.6:1 396 over no prob
Old Feb 13, 2007 | 03:55 PM
  #18
SS Joe's Avatar
Originally Posted by seawolf06
Is there really any difference between the LT1 and LT4 starters? I was wondering the same thing since mine is off right now and would be easy to replace.
There isn't a difference between LT1 Corvette and LT4 Corvette starters, but there is a difference between the Corvette starter and the F-body LT1 starter. The Vette starter is a Nippondenso, and is more squared off looking; it doesn't look like any Chevrolet starter. The LT1 F-body starter looks more conventional, but it smaller than the typical Chevy V8 starter from Gen1.
Based on the broken plastic planatery gears that came out of my F-body LT1 starter, I'll be upgrading if they break again (got it fixed cheap by the local rebuild shop).
Old Feb 14, 2007 | 01:49 AM
  #19
OneFlyn95z28's Avatar
Stock starter on over a dozen high CR LTx cars and no problems
Old Oct 2, 2007 | 12:42 AM
  #20
rock1501's Avatar
I know this thread is old but my motor is 13.6:1 and the stock starter works but it takes a bit of effort
I was wondering what my options are for higher torque starters
Old Oct 2, 2007 | 01:20 AM
  #21
neil350's Avatar
I had a mini Starter from Jegs, lasted a year before it started giving me problems. When it got hot it would stop working. Went back to stock, no issues, I have a bolt on car with Hooker LTs
Old Oct 2, 2007 | 09:18 PM
  #22
LB9GTA's Avatar
I have 11-1 compression and I have a digital 6 msd ignition with a start retard. Whenever the tach signal is below 400rpm, it retards the timing 20 degrees.
Even when my engine is hot, it starts, no problem.
Old Oct 2, 2007 | 10:59 PM
  #23
rock1501's Avatar
I have a digital 7 box and I retard the timing 20 degrees as well
I guess the differance between 11:1 and 13.6:1 is a fair bit
Old Oct 2, 2007 | 11:34 PM
  #24
seawolf06's Avatar
That seems like a lot. Is there a reason you chose 20*? I'm interested since I'll be running about 11.5:1.
Old Oct 3, 2007 | 01:32 AM
  #25
speed_demon24's Avatar
Interesting... My motor hydrolocked when I tried to start it on coolant with an LT4 starter. I have put 3000 miles on it since them so I'm hoping the rod is fine.
Old Oct 3, 2007 | 04:24 AM
  #26
SS Joe's Avatar
Quoting myself... the same gear broke again, by the 2nd start. I replaced it with a Summit brand Hitachi style starter, and it is fine so far. I never had an issue with the stock starter turning the engine over, it just liked breaking the plastic gear.
Old Oct 3, 2007 | 08:23 AM
  #27
rock1501's Avatar
the guy that tuned my car told me to use 20 degrees
Old Oct 3, 2007 | 12:22 PM
  #28
FASTFATBOY's Avatar
I have an LT4 starter on a 12.77 to 1 383, works very well.
David
Old Oct 3, 2007 | 06:52 PM
  #29
marshall93z's Avatar
This is YOUR thread!
Old Oct 3, 2007 | 06:54 PM
  #30
You'd know if all wasn't well. Broke part of the piston too....and knocked pretty loud because the rod was SHORTER, which caused the base of piston to hit the crank every rotation!
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
pimpss96
Feb 12, 2015 01:28 PM
Killer94z
Jan 13, 2015 12:06 PM
