355 w/o power adder need suggestions
Old Feb 13, 2006 | 10:20 PM
  #16
Steve0's Avatar
Re: 355 w/o power adder need suggestions
Originally Posted by Jeremy95TA
He's doing a 355. I don't think that you can use the stock pistons after that. I don't think they will fit properly...
Youre right. You will need new pistons after boring the cylinders over.
Old Feb 14, 2006 | 01:10 PM
  #17
Cool ZR's Avatar
I am not set on 355, I figured with the car having about 100k miles on it, I would have to go to 355.
Also, does anyone know of a thread that covers the rest of the basic stuff to buy for the rebuild? ARP bolts, which kind of optispark etc?
Old Feb 14, 2006 | 04:12 PM
  #18
Jameslt1TA's Avatar
Stock polished crank, stock rods and arp rod bolts(resize the rods) will work.
Do not reuse the stock pistons or its a waste of a rebuild, they are heavy and the weakest link in the lt1 bottom end... I did and i put a hole in one after a 1000 miles.
You could always just use the bottom end you have now...but if you plan on reusing the stock pistons, dont bother taking any of the bottom end apart.
Old Feb 14, 2006 | 07:25 PM
  #19
Cool ZR's Avatar
James,
What else did you replace when you did your motor? What kind of money did it run you? I am trying to get together a realistic shopping list and budget before I start.
It's one thing to think the heads are $1000 with a cam, but it's all the small stuff that adds up in a hurry. My guess would be in the $3000 range.
dluna333
15
Mar 13, 2015 12:30 PM
94Z28LS1toLT1
Mar 10, 2015 09:52 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
