355 vs 350
Old Apr 18, 2003 | 02:40 PM
  #16
rskrause's Avatar
Moderator
The short stroke alternative is viable for a high rev setup. But for most people building a street or street/strip setup a stoker is the way to go. Added cubes are an excellent path to more hp. Provided you are upgrading the rotating assembly anyway, the additional cost is next to nothing - just some clearancing on the block. Yes, a stroker will wear out a bit faster due to higher piston speeds. But performance motors in street or streeet/strip seldom wear out. They either break or the owner decides to upgrade long before the wear per se becomes an issue.
Rich Krause
Old Apr 18, 2003 | 03:01 PM
  #17
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
a forged piston/rod/crank wont "wear out" any slower than a hyperutectic (sp?) one. If the motor goes, its gernading-
and under 500hp isn't a real issue
Old Apr 18, 2003 | 05:41 PM
  #18
94SLUG's Avatar
True True, Hypers in my case would not have made sense. Hyper SLUGS should last a bit longer in most cases.
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
MDZ28
Sep 7, 2015 09:16 PM
Rittmeister
Aug 7, 2015 01:13 AM
