355 stroker
Old Jun 5, 2004 | 05:49 PM
whiteZ2895's Avatar
355 stroker
what do i need to make my stock lt1 into a 355 stroker? what kind of hp would it be runnin?
Old Jun 5, 2004 | 05:57 PM
1984camaroz28's Avatar
355 is just a stock Block Bored .030 over wich gets u another 5ci
I think you thinking about a 383 stroker. You whould need a .030 bore. a 3.750 stroke crank. and a 5.7 or 6in rod depending on what piston you are using. You whoudl also need to have your block machined for the bigger stoke crank
Old Jun 5, 2004 | 07:16 PM
whiteZ2895's Avatar
im not confused i just need ed to know if i needed a longer rod and stuff like that because i looked at what i need for a 383 and its way out of my budget for now.
but thanks for the information
Old Jun 5, 2004 | 07:48 PM
12SCNDZ's Avatar
A Chevrolet 350 is a 4.00" bore block with 3.48" stroke crank and 5.7" rods. A 355 is achieved by a .030" overbore on the block (4.030"). It is possible to build a 6" rod (or longer) 355, but you'll need pistons with a different pin location.
Long rods USUALLY make more power, but they're not very "nitrous friendly" because the rings are usually moved closer together when the pin is moved up.
Rod length doesn't affect cubic inches. Bore and crank stroke are the only things that will affect displacement.
Frank
Old Jun 6, 2004 | 01:01 AM
SStrokerAce's Avatar
Let's add in the simple equation for finding cubes......
Bore x Bore x Stroke x # of cylinders x .7854 = cubes
4.00 x 4.00 x 3.48 x 8 x .7854 =349.848 cubes
4.03 x 4.03 x 3.48 x 8 x .7854 =355.115 cubes
Now for the 383 vs. 355 question. You need a new crank to get to a 383 but for a 355 you can resuse the stock crank, and rods if you want, but you might as well put in new rods and pistons.
Bret
Old Jun 6, 2004 | 01:30 AM
Now for the 383 vs. 355 question. You need a new crank to get to a 383 but for a 355 you can resuse the stock crank, and rods if you want, but you might as well but in new rods and pistons.
Bret
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
whitehooptie
Aug 17, 2015 08:35 AM
