355 questions
355 questions
Ok guys, I have read a lot about the 355 the past couple days and have a couple questions about it.
1) The stock crank can be reused, only longer connecting rods are needed? Is this true? If not what is a good crank to run? Also how much horsepower can the stock crank handle?
2) How much horsepower can the stock 2 bolt handle before needing upgraded to the 4 bolt? Should this be a concern with a 355? I am going to buy a seperate short block to build, don't the vette short blocks have the 4 bolt already? Where is the best place to find a decent short block?
3) What would be the best set of heads to get for this? I know it all depends on my goals, but I would like to get as much out of this motor as I can. I was thinking of LT4 AFR's, but I feel it might be a waste of money.
4) Does port matching an intake to the heads make that much of a difference?
Overall I want the bottom end to be completely bullet proof, everything will be forged. I also want to get as much horsepower out of this motor as I can. I really don't want to get into a 383, even though the cost might be the same...I just don't want big cubes. Thanks for the advice.
Re: 355 questions
But you said everything is going to be "forged" so that rules out the stock crank and the stock rods.
Seems like you are a little confused on exactly what you want to do?????
I want everything to be forged, but I am unsure about the crank. I know I am replacing the connecting rods and pistons, obviously, for sure. I really just want a strong, reliable engine. I know a forged crank can handle more power, but if the stock crank can handle what i want then I might not change it. I would like to have somewhere around 450 horsepower. There will never be nos on this car, if any FI.
Lt1son
Dec 31, 2014 01:35 PM
