355 383?
Old Jun 3, 2006 | 09:58 PM
TRIPOWER's Avatar
355 383?
besides the displacement what the difference i know the 383 has more torque but besides that what advantages are there in the two?
Old Jun 3, 2006 | 10:07 PM
1racerdude's Avatar
Re: 355 383?
The stroker will let ya build the same HP/TQ and not be as radical for driving on the street.
Ya can get about the same HP out of either but a 355 is going to be a high maintenance unit.
Remember there is no replacement for displacement.
Old Jun 3, 2006 | 10:11 PM
TRIPOWER's Avatar
Re: 355 383?
why the high maintenance on the 355?
Old Jun 3, 2006 | 10:18 PM
1racerdude's Avatar
Re: 355 383?
It has to be a lot more radical than a 383 to put out the same HP and that makes the valve train more prone to break and it has to have different clearances and that makes it wear out sooner. It will have to have very large heads--'bout equal to the 383 and ya got to turn the snot out of it to get the same HP unless ya gonna put a weeny cam in it and hope for 375/400HP at the flywheel at 6000.
Old Jun 3, 2006 | 10:39 PM
StephenDeli22's Avatar
Re: 355 383?
So a 383 would be more streetable?
Old Jun 3, 2006 | 10:51 PM
1racerdude's Avatar
Re: 355 383?
Yes at the same HP level.
Old Jun 3, 2006 | 10:54 PM
sam pace's Avatar
Re: 355 383?
like the old saying goes
Old Jun 3, 2006 | 11:08 PM
1racerdude's Avatar
Re: 355 383?
user 647483's Avatar
Re: 355 383?
I asked a similar question a while back :
Originally Posted by calfirebird
Peak Hp wont be that much diffrent between a 383 and a 355. The Hp under peak will be higher with that attibutiated to the higher tq. A 355 on stock ported heads will peak around 6700 where a 383 will peak around 6100-6300. cant go wrong with either one.
Old Jun 3, 2006 | 11:39 PM
blackz97's Avatar
Re: 355 383?
After riding in a similar setup to mine but 383 i kinda wish i would have went the 383 route. The mid/low range power difference is pronounced. BUT i love running my motor up to 6800 and the 383 would fall off long before then. When i was building my setup i was going to be road racing, but now since i have been doing mostly street driving the 383 would have made more sense.
Just my .02
Steve
Old Jun 4, 2006 | 02:53 AM
BlackBird97's Avatar
Re: 355 383?
I guess it all depends on what you want to do with your car. Road racing or drag racing. In a straight line, 383 is by far the best rought you can go, unless you are running No2 . If you make a 355 most of those types of engines are good for for running No2. Allthough, it all depends on the componets you use to make the engine. The better the parts " Forged/ Hardened" the more durrable it will be. All depends who builds the engine and what you want to do with it.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
