can I hit 400 rwhp?
Old May 7, 2006 | 01:21 PM
Beyonce Knowles's Avatar
can I hit 400 rwhp?
Can anybody think of a way to get me to 400 rwhp without getting a bigger cam? Right now I'm at 375. I've got LE 2 heads and LE1 cam, long tubes, ory, VERY restrictive muffler, slp cai, stock TB, electric water pump, 1.6 rr. Thats about all the power things I can think of. THe only things I can think of are a cutout and bigger TB. I've seen people gaining 15 rwhp with stock internals from a cutout, TB has to be worth a few. Is there anything else I'm forgetting? I know there are probably better ways for the money to be spent, but saying you have 400 rhwp is just so much cooler than 399.
Old May 7, 2006 | 01:26 PM
Josh'95Z28conv's Avatar
Re: can I hit 400 rwhp?
Get a good flowing exhaust, or cutout, and bigger TB. Maybe an uderdrive pulley, EWP, and little stuff like that. You should be able to hit 400.
Old May 7, 2006 | 01:27 PM
ahhh, UD pulley, good thought. Never though about that.
Old May 7, 2006 | 02:06 PM
sleeperMULLET's Avatar
is your intake ported or is it just gasket matched? I agree with josh, a bigger tb will help alot, but if your still at 350cid try to stay below the 58mm TB. and once you get more air coming in you need to get the exhaust out faster, the engine has to "poop" before it can "eat" if you know what i mean
Old May 7, 2006 | 03:25 PM
taylorcrzy's Avatar
Have you had it tuned as well? What gear are you running in the rear?
Old May 7, 2006 | 05:37 PM
Ive actually got one for sale Its in the classified section if you're interested. My new setup has a one piece balancer.
Old May 7, 2006 | 05:56 PM
ulakovic22's Avatar
Thumbs up Re: can I hit 400 rwhp?
With that set-up you should be able to hit 400 rwhp. You need to get a better tune, ported intake and 52mm TB. What kind of catback do you have that is so restrictive? I have the LE1 package and I'm at 380, so with better flowing heads you should be able to hit close to 400 rwhp. I'm adding a ported intake and EWP and I'm gonna get a dyno tune instead of the MadZ28 tune I have right now and I'm hoping to be around 390 at least. Is this set up on a stock shortblock or does it have a lot of miles? Mine is on a new shortblock and I'm running about 11.3:1 static and just under 9.0:1 dynamic. Good luck with everything, I'm sure you will get there once it's all dialed in.
Old May 7, 2006 | 09:35 PM
my94blackz's Avatar
Dont waste time buying a TB!! Cut out and a granitelli mass air.
Old May 7, 2006 | 09:55 PM
blksunshine's Avatar
get 3inch duals, throttle body,and a good tune
Old May 8, 2006 | 01:00 AM
Bersaglieri's Avatar
Forget the cutout, some folks are losing power with them. 2.5/3" duals, no cats, ASP 23% UD Pulley, 52-58mm TB, Aluminum driveshaft, lighten the car or ET/Trap, and dyno tune should do it.
Dyno numbers are cool when they win races, which they dont. Go hit the track and see where your at. ABA383 dyno's anywhere from 370ish to 400ish and runs mid 11's, so dont let dyno's bother you.
-Dustin-
Old May 8, 2006 | 06:56 PM
Originally Posted by Bersaglieri
Aluminum driveshaft
Do you really think the fraction of a HP gain you get by that driveshaft is worth how much weaker it is than the stock LT1 DS?
Old May 8, 2006 | 07:23 PM
SS MPSTR's Avatar
I believe ABA383 has an A4 too, which again skews the hp to et expectation.
Old May 8, 2006 | 09:01 PM
besz28's Avatar
cut out you WILL gain at least 10 HP I GUARANTEE IT. or i 'll pay pal you 10 bucks
Old May 8, 2006 | 09:16 PM
97silvermaro's Avatar
cutout gave me exactly 10hp
Old May 8, 2006 | 10:54 PM
turbo_Z's Avatar
Larger cam and cutout sure wouldnt hurt. You gotta add some decent mods to make up that much power.
