350 block??
Old Oct 6, 2006 | 03:20 PM
gpss97's Avatar
350 block??
ok..on the 350 blocks that take the distributor up top..can you use one for an lt1 or is it a totally different block?? i was given one and he said it would work, but he doesn't know what year it came out of..its already setup for a 383 but i didn't know if since mine uses an opti if it would work or not..i don't know what/what not to look for on these motors. if someone could let me know if it will work or not i'd appreciate it.thanks
mike
Old Oct 6, 2006 | 03:30 PM
Colin91Z's Avatar
Re: 350 block??
No, LT1 blocks look very similar, but are quite different in many ways. It won't work.
Old Oct 6, 2006 | 03:56 PM
gpss97's Avatar
Re: 350 block??
not questioning your answer, but why won't they work?? just so that i know how would i know if it is the right year to work in my car
Old Oct 6, 2006 | 04:04 PM
Eric@Victory Racing's Avatar
Re: 350 block??
Casting number 327 will work in your vehicle.
Old Oct 6, 2006 | 04:06 PM
Re: 350 block??
The LT1 (Gen 2 SBC) differs from the Gen 1 SBC block:
-front end casting different to accept the Opti
-front end casting different to accept the reverse flow routing of the coolant pump
-internal coolant passages revised to accomodate reverse flow cooling. Gen 1 SBC coolant passages do not correctly match the coolant passages in the LT1 heads. The LT1 heads do not accomodate the coolant flow through the intake manifold that the Gen 1 SBC uses.
-The thermostat housing on an LT1 engine is "external", not in the block.
Old Oct 6, 2006 | 04:14 PM
Colin91Z's Avatar
Re: 350 block??
Thanks Fred
Old Oct 9, 2006 | 07:46 AM
gpss97's Avatar
Re: 350 block??
thanks for the info injuneer..this if my first camaro so just trying to figure this stuff out.
Old Oct 9, 2006 | 07:49 AM
Re: 350 block??
Here's a little background info that helps understand the LT1 vs. Gen 1 SBC:
http://www.automotiverebuilder.com/ar/ar99928.htm
240ssLs3
Jul 13, 2015 05:06 PM
camaro02DK
Jul 5, 2015 09:04 AM
geinsteder
May 6, 2015 06:02 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
