305 cam swap, rr's, pushrod length
Old Jun 28, 2007 | 10:23 AM
GaJoe's Avatar
Quick question...I am going to put the 305 cam in my 94 lt1....I am also swapping over to 1.6 rr's....not sure if I am planning to take the heads off or not...but if I don't (and it's all stock) and change this setup, how will the length of the pushrods be affected? I know it's best to measure but I was just wondering if someone had any experience w/ this....thanks.
Old Jun 28, 2007 | 12:17 PM
Chris95LT1's Avatar
You would most likely be fine with the stock length. (7.2?) But, you answered your own question, just measure to be safe. For example, the hotcam kit comes with 1.6 RR's and they are made to swap right in with the stock pushrods. I have the hotcam kit going in right now and i ordered the comp cams length checker, but havent gotten that far yet.
Old Jun 28, 2007 | 12:36 PM
69gto96z's Avatar
Im puttin a comp 306 cam in mine with 1.6 roller rockers and .010 thinner head gaskets than stock and will be using the stock pushrods
Old Jun 28, 2007 | 02:48 PM
GaJoe's Avatar
Thanks.... 69gto96z, I am thinking about going w/ the .010 thinner head gasket as well....not sure if I'm going to take it down that far or not...I think I'll just get everything on and measure...I was trying to buy a day or two....I guess measuring and then ordering will at least give the sealant on the intake time to set up....haha...
Old Jun 28, 2007 | 03:08 PM
69gto96z's Avatar
Yeah, I decided just to re-use the ones Ive got, they are from a 94 motor, and the 94's had hardened pushrods.
Old Jun 28, 2007 | 05:12 PM
GaJoe's Avatar
didn't realize...I have a 94 motor...are you saying they would be fine to use with guideplates?
Old Jun 28, 2007 | 05:37 PM
69gto96z's Avatar
Thats correct, 94s are hardened.
Old Jun 28, 2007 | 08:01 PM
ricehammer's Avatar
Stock pushrods will work. Not shure that the stock valve springs can handle the 0.537 intake and exhaust lift though.
Old Jun 28, 2007 | 11:38 PM
GaJoe's Avatar
nope, the springs will be comming out...thanks for the info on the pushrods...that is great...
Old Jun 29, 2007 | 02:44 PM
2000GTP's Avatar
When in doubt, it is just always a good idea to measure.
Old Jun 30, 2007 | 01:08 AM
pat35's Avatar
GaJoe i see you got the cam. ha i am ordering a pushrod lenth checker. when i am dune with it its yours . ordering it monday probly be seting the engen up in 3 weeks after that its yours .and use comp cromoly harden pushrods. sary
its late just got back from towers long drive 2 ours there 3 1/2 back. just to see if any one had the le2.2 or le1.5 .to see which i am to use got both selling one .not shore which i am going to use on this engen.sary about the spelling have deslexia and i am beet
Old Jun 30, 2007 | 09:57 AM
GaJoe's Avatar
Yeah man, everything got here perfect...you are the man..just a few things left to get and I can start working on this thing.....let me know when you get rested man and I'll call ya...thanks.
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
