300rwhp and 325 rwhp?
Old Sep 3, 2008 | 11:05 PM
lt1stroker's Avatar
300rwhp and 325 rwtq?
I just had the car dynoed for the first time since i bought it. I havent got the chart yet but the guy at Newtech told me these numbers. Does this sound right for my car?
Old Sep 3, 2008 | 11:18 PM
karpetcm's Avatar
Ya if you have a hot cam you should be around 320-330 rwhp depending on how healthy the motor is, ofcourse im also basing this off the mods in the sig.
Old Sep 3, 2008 | 11:27 PM
MarcR94v6's Avatar
stock heads - untouched? BBK headers - shorty, mid, full? Even with untouched heads, I should think you'd be a little higher. I am probably almost where you're at now, and my cam is quite small and my heads weren't even flowbenched because they ported them lightly.
Old Sep 3, 2008 | 11:33 PM
lt1stroker's Avatar
There shorties but i purchased some Pacesetter longtubes. How much do you think the LTs would add?
Old Sep 4, 2008 | 06:49 AM
JakeRobb's Avatar
Super Moderator
Not much in terms of peak power, but they'll add a bunch of low-end torque.
Old Sep 4, 2008 | 08:54 AM
slomarao's Avatar
+1 on the low end torque with the LT's.
I have high dyno numbers because my car is a m6/10bolt but still look at my sig. With your cubes and cam you shoud def. have more torque than i am putting down.
Get some heads, that bigger motor needs airflow. And the stock heads are whats holding it back.
Have you taken the car to the track?
Old Sep 4, 2008 | 09:47 AM
ulakovic22's Avatar
ur numbers sound about right for what you have.
Old Sep 4, 2008 | 06:05 PM
96capricemgr's Avatar
I agree with those saying the heads are what is killing it, followed by the cam.
People are too quick to add displacement without figuring on FEEDING the extra displacement.
Often when things are done poorly like this they also use old school thick ringed heavy pistons which hurt power compared to what a stock shortblock would have delivered.
Old Sep 4, 2008 | 07:09 PM
Originally Posted by Z28Roxy
I would imagine it's the other way around (longtubes adding a bunch of top end)???
Depends on the primary diameter. A small primary will provide good low end torque, because it keeps the scavenging high at low RPM. But then at high RPM, the small primary diameter chokes the engine. I had a set of 1-5/8" JBA shorties that did exactly that.
Old Sep 4, 2008 | 07:56 PM
2000GTP's Avatar
Hard to say, the numbers sound like they could be pretty close. The combo could be opened up a little bit, stock heads and a Hotcam on a 383 bottom end.
Old Sep 4, 2008 | 10:02 PM
JD311's Avatar
not to steal this thread but.......I have a set of 1-5/8 LONG tubes, not 1-3/4 like most. My car has ALOT better bottom end and top end than before. of course I also had stock manifolds and stock catback with a flowmaster in place of the stock muffler oh and ORY. The headers were modified (pipes moved port matched etc, they were off of an old chevelle and I added 2-1/2 true duals with dumped flows before rear axle. Freebie stuff lol. Anyway a 383 combo needs to be right. We built an older 383 sbc for a guy, I asked him what he wanted first then told him what to get. He brings me a bunch of mismatched stuff. KB hyper pistons, lunati rods, eagle cast crank street stuff. Then the heads- Pro action that flowed over 300 cfm/230cc and a 490/230 flat hydraulic cam victor intake and 750 carb!? Needless to say that thing was a turd. Had a 2500stall and like 2.73 gears. What a waste. Sorry long winded. Get those heads ported and a GOOD cam!
Old Sep 5, 2008 | 12:34 AM
lt1stroker's Avatar
I would get heads and a new cam but money is low and i hate to spend money on labor. I am taking an AutoTech class and hopefully i will be able to take the heads of my self and send them to a machine shop. Is really hard to take heads of? And how long do you think it would take to remove and how much rwhp would it add if i got them mildly ported? thanks
Old Sep 5, 2008 | 08:56 AM
slomarao's Avatar
the heads could provide anywhere from 10-75hp depending on the amount of work and the castings used.
If you could get Le1's (800) and see a 30-40 hp gain. Look in the FS section. Theres always deals.
Old Sep 5, 2008 | 09:04 AM
2000GTP's Avatar
Do a search, there should be some writeups and posts on head removal/install. How long it takes depends on your skill level, but it is nothing that is impossible to do.
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
