30 lb injectors ok
Old Aug 6, 2005 | 11:46 AM
red 95 z28 lt1's Avatar
30 lb injectors ok
hey i just had built by sk speed a 383 with a le2 heads and cam package with a 9:8:1 cr. i was wondering if 30 lb injectors will do, im guessing my horsepower range is somewhere between 450 to 480
Old Aug 6, 2005 | 12:09 PM
Re: 30 lb injectors ok
480 flywheel HP, a 0.48 BSFC and an 85% duty cycle says you need an injector that will supply 33.9#/HR. The only way a 30 will work is if you have a very efficient tune (0.45 #/HR/HP BSFC) and you drive the injectors at 95% DC, which is not recommended.
Old Aug 6, 2005 | 12:14 PM
96capricemgr's Avatar
With that low compression are you planning on boosting it? From Fred's calculations looks like a 36# is the way to go now but if looking to boost later(again based on compression) then you might as well just go larger now rather than buy two sets.
Old Aug 6, 2005 | 12:28 PM
Silvershark's Avatar
i would go with some ford 42lb'ers if you are going to boost down the road. My buddy has a supercharged transam and he is doing well with his 42lb'ers.
Old Aug 6, 2005 | 01:34 PM
so i should go with 36 lb? what company should i get? also i will have madz28 tuning re tune the computer for the new engine, i dont plan on any power adders at least till next year
Old Aug 6, 2005 | 04:50 PM
If you buy 42lbs. you should be able to use then till and after the boost. If you go with 36lbs. you will have to buy another set when you do the boost.
Old Aug 6, 2005 | 05:06 PM
WS Sick's Avatar
I'm running the SVO 30 #ers and with GM fuel pressure they are closer to 32 #s. At about 6700 rpm my injector dutycycle gets in the 90s according to Datamaster TTS. When I redo the motor I will add 36 #ers.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
