30# injectors worth it?
Old Jun 22, 2004 | 04:49 PM
AdamZ1LE28's Avatar
I wanna get the 30# Ford Racing Injectors from thunderracing.com, but for $300 I want to make sure they're worth it. How much power will I gain??
I know I'll hafta get re-tuned by Bryan at pcmforless.com, but thats okay because I need to after my header/no cat install anyways.
All input welcome. Thanks.
- Adam
Old Jun 22, 2004 | 04:57 PM
llafro's Avatar
Unless you have some serious mods, such as heads/cam or supercharger, there is no reason to go with bigger injectors. The stocker injectors are fine up to about 400 crank HP.
BRAD
tireburnin's Avatar
As far as I know, you won't see any gain from injectors unless you are running lean. With your mods, stock injectors will be fine. $300 could be better spent else where unless you are doing a healthy heads and cam that isn't in your sig.
-Sean
Devinfoote87
Feb 12, 2016 03:21 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
colts0455
Sep 2, 2015 12:41 PM
4586
Aug 22, 2015 01:09 AM
whitehooptie
Aug 17, 2015 08:35 AM
