3" true duals overkill?
Old Sep 19, 2005 | 07:16 AM
  #16
OldSStroker's Avatar
Re: 3" true duals overkill?
Originally Posted by BD380
But 400hp is 400hp. What difference does it make if it's making that power on spray or on motor? The car won't be raced on motor, therefore I don't care how it performs on motor. Basically you're saying that 3" piping is beneficial at 400hp, which the car should make on spray, correct? Or are you saying that a 400hp motor car with the addition of spray would necessitate the use of 3" piping?
I guess I'm not being very clear.
If your sprayed power is 400, even if that's rwhp, my suggestion is that 2-1/2 is more than adequate.
If your sprayed power is 600 or so fwhp, which I doubt you will achieve on a stock engine, go for 3 inches.
If you think you'll get to 500 fwhp, you could probably go either way.
These are general numbers, not cast in stone. Your results may vary.
You could always take a poll and let the votors decide.
Personally, I do care how my engine performs on motor, which is maybe 99.9% of the time. (40 drag runs on juice every 10000 miles).
Good luck!
Old Sep 19, 2005 | 06:20 PM
  #17
BD380's Avatar
Good luck!
All right, thanks. Now I need to find a company that sells a 2.5" setup. I've seen people talking about Dr. Gas and a universal Summit kit, but I can't find too much info on either of them. Are there any other alternatives? My true duals will also be going on AS&M midlengths, so I'm aware there will be some additional fabrication required.
Old Sep 19, 2005 | 06:46 PM
  #18
TruDualed95Z's Avatar
i have 3" duals and will never fully utilize them. would i go 2.5" if i had the chance? naw. the sound is unbelievable.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
