3" single ex. enough for 400 rwhp?
Old May 10, 2006 | 05:11 PM
jonesy's Avatar
finally got the motor out of my car and it has Flowmaster ex. from cat back which is 3"( single pipe) the mods I am doing are GM 847, rebuilding to 355 and bumping compression to 11:1, ported heads w/ 2.02/ 1.60,Hooker headers and bolt ons. My question is that I did the math comparing dual 2 1/2 ex compared to headers to 3" y and 3 " back to muffler then back to dual 3". Theoretically to flowcomparable to the dual you need 3 1/2 single pipe. Are people making 400 plus rwhp through 3 in single. My goal is 400 to 425 and would like any input.
thx,
jonesy
niles, mi.
Old May 10, 2006 | 05:17 PM
FuryZ28's Avatar
Re: 3" single ex. enough for 400 rwhp?
Single 3" should be good for a lot more than 400 rwhp...
Old May 10, 2006 | 06:00 PM
speed_demon24's Avatar
You could make 400rwhp with a single 3" catback, but it will probably be a restriction. When I went true duals, I felt a SOTP gain, but for all I know its in my head. I haven't felt a SOTP gain from a mod in awhile, this is something I'm pretty sure i feel though. I'll know for sure when I get on a dyno for a dyno tune.
Old May 10, 2006 | 06:36 PM
jonesy's Avatar
where can you get TRUE duals ? do both pipes run where the single did, then split off after axle?
Old May 10, 2006 | 08:34 PM
zx1216's Avatar
My buddy rolled 420ish with a le2 383 through a 3 inch pipe and magnaflow muffler so it is done all the time, If you are looing for more than that then the 3 inch pipe will start to be more of a restriction.
Old May 10, 2006 | 08:39 PM
89TramsAmGTA's Avatar
I agree with the above post. Sure the 3" will do it but you are leaving power on the table. At that HP level you should be thinking of a 3.5" system.
Old May 10, 2006 | 08:50 PM
jonesy's Avatar
thx all , I can rest now , just wanted to confirm that I felt that the 3" would restrict it. Try to slide local muffler shop some cash and run true duals minus the cats
Old May 11, 2006 | 06:12 AM
TQdrivenws6's Avatar
On the dyno my car put down identical numbers through the 3" system with a magnaflow muffler as it did with a 3" cutout. Take that FWIW but if you can do 3.5", I don't think it would hurt other than starting to limit your options on mufflers.
Old May 11, 2006 | 02:19 PM
Magnaflow has come out with a very nice 3.5" muffler. It is part number 12909. It is of the straight through design for high flow but suprisingly on the quiet side.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Ks0209
Oct 1, 2015 07:32 AM
Z Power
Sep 19, 2015 11:19 PM
