3.73's or TC?
Old Jul 30, 2003 | 01:46 PM
Speedy T/A's Avatar
3.73's or TC?
my b-day is comin up and i just want to get something that will take the most off my 1/8 mile. Should i upgrade my 2.73's to 3.73's or get a stall?
Old Jul 30, 2003 | 01:53 PM
Smoke T/A's Avatar
Get a stall. You will maybe find a few tenths with 3.73's. A higher stall will net about .5 thents off your time depending on what you get. HTH
Joe
Old Jul 30, 2003 | 02:17 PM
87transam383tpi's Avatar
yes definately get the TC, then do gears. a stall is much better fro first thing to do IMO cause then u still have your MPG but also have a better launch.
Josh
Old Jul 30, 2003 | 02:36 PM
TedH's Avatar
Get a good lockup stall first. Next thing you will probably want is tires. You also want a tranny cooler as a higher stall will make your transmission run hotter so do it right the first time.
Old Jul 30, 2003 | 03:02 PM
Eddie95Z28's Avatar
The wording of tnthub's post might make it sound like you should get an aftermarket cooler soon after the TC. But you should do it at the same time... don't run a aftermarket stall without a good auxiliary transmission cooler.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
