3.480 or 3.500 crank?
Old Mar 11, 2008 | 09:37 AM
jay_rich's Avatar
Okay The mahle pistons I am looking at say a 3.500 stroke. I plan on buying a scat or eagle forged crank. And Forged 5.7inch Rods (scat or eagle)
Does it matter if I get a 3.480 or a 3.500?
Its going to be a forged 355 build.
Thanks Jay
Old Mar 11, 2008 | 09:59 AM
jsetzer's Avatar
3.5 will give you a 357 and a little higher compression. I have had 3 motors with 3.5 stroke and no problems, just run your numbers first.
Stock is a 3.48.
If you have a choice get the stock one, if not I have bought mine as kits and for some reason the 3.5 is always way cheaper.
Old Mar 11, 2008 | 10:47 AM
blackztpi's Avatar
doesn't really matter. as long as the piston fits the rod length
Old Mar 11, 2008 | 12:59 PM
jay_rich's Avatar
So i can have a 3.480 crank....a 5.7 inch rod with a 5.7 piston (with a 3.5 stroke and its okay)
Jay
Old Mar 11, 2008 | 03:27 PM
1989TransAm's Avatar
Yes, I know of people doing just that. However they are also figuring in their quench, compression ratio etc. That way they hardly have to deck the block if at all depending on the situation and get a little extra power.
Old Mar 11, 2008 | 10:05 PM
Zigroid's Avatar
if your piston is .025" down in the hole with a 3.48" stroke, it would be about .015" down in the hole with a 3.5" stroke. couple that with a Mr Gasket .026" thick head gasket and you got a nice .041" quench without decking the block. that would put your compression at about 11.2 with stock heads.
Old Mar 11, 2008 | 10:11 PM
jay_rich's Avatar
Shoulda added that they are -26CC pistons for boost :P
So just to verify i can use a 3.480 crank with a 3.500 piston without issues if the rods are corrects?
Jay
Old Mar 12, 2008 | 12:34 AM
quickSS's Avatar
Let me know if these people are getting a 1-piece rear crank (3.500" stroke). I've been looking for a crankshaft like that, (no luck in finding).
Karl Ellwein
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
